no lights???
Old Oct 20, 2010 | 07:51 PM
cumminsp12v's Avatar
Default no lights???
on my way home from dinner my parking lights, cab lights, and my pillar gauge lights went out. fuses are good. my dash lights and radio still work. turn signals and brake lights still work also. any help would be nice. thanks
Old Oct 21, 2010 | 08:24 AM
dan33klein's Avatar
Check the switch and wiring harness. There common to go bad
Old Oct 21, 2010 | 12:13 PM
ok thanks, i talked to one of my friends and he said the same thing about the switch. could the switch go bad because of to many running lights on the truck?
Old Oct 21, 2010 | 12:46 PM
cumminspwr11's Avatar
ya its possible dodge didnt wire those switches up real good, too much draw on it will cause problems, i put a high wattage headlights in my truck and the extra power draw melted some of my wires, also heard of trailers with alot of lights causing the same sorta of probelms with the headlight switch, putting relays on your headlights works out pretty good, takes a big power draw off the headlight switch
Old Oct 21, 2010 | 01:05 PM
dan33klein's Avatar
Wire in relays.
Old Oct 21, 2010 | 01:26 PM
when i did my relays it fix my flickering problem and made my headlights brighter
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
carid
Nov 10, 2014 02:15 AM
