housing swap question
Old Oct 19, 2010 | 12:21 AM
redrocket9793's Avatar
Default housing swap question
Would you be able to put a hx-35 exhaust housing on a hx-40? The spool time is killing me
Old Oct 19, 2010 | 03:09 PM
cumminspwr11's Avatar
what housing is on your 40? you could put a 12 or 14 on there but your would need to find the exhaust turbine out of a 35, if you have an 18 or bigger housing you could find a 16cm that will go right on but those still spool slow
the way i got my 40 that i have is i found the whole hx40w sitting on the ground at the shop with no exhausting housing on it, so i took it all apart and put the exhaust turbine and 12cm housing off my burned up 35 on it and it worked great, i then bought the 14cm housing off a guy and put it on, whole turbo only cost me 100bux out of pocket
Old Oct 19, 2010 | 11:07 PM
I think mine is a 18 and thanks I wanted to make sure before I took my turbo off and tore it appart
Old Oct 20, 2010 | 10:16 PM
12valvetater's Avatar
The housing will need to be machined for it to work.
Old Oct 20, 2010 | 10:19 PM
How far and could I do it myself?
Old Oct 21, 2010 | 10:35 AM
do you mean machined so that the 40s turbine wheel will fit in the 12cm housing?-
12valvetater
Old Oct 21, 2010 | 09:48 PM
blackout94's Avatar
it was a16 bro and good luck should have got a hybrid
Old Oct 21, 2010 | 10:02 PM
O ok thanks and I know but I didn't have the money so ill make my own haha
jeffersonl
Nov 15, 2015 07:35 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Duncan
Oct 28, 2014 12:34 PM
jeffersonl
Oct 25, 2014 06:46 AM
