lift pump mystery
Old Oct 19, 2010 | 12:16 AM
yamadude's Avatar
Default lift pump mystery
i used to be able to hear the lift pump for a few seconds after shutdown, but now i dont hear it. hear is a list of what i have checked.
1. fuse is good.
2. there is power at the LP while engine is at idle
3. i can put my hand on the LP with engine at idle and feel it working
4. with engine at idle i opened the T-handle for 30 seconds and had good fuel flow with no coughing or dieing. closed T-handle and opened the valve on top of filter and had fuel there too.
5. no loss of power, not stalling or hard to start. i can jump the LP and it will run. so why dont it run anymore after shutdown? also noticed that the LP doesnt run with trans in reverse and key on. everything points to a good LP. and since theres power at the LP with engine at idle the OPS checks good too. am i missing something?
Old Oct 19, 2010 | 07:34 AM
Crazy's Avatar
1. fuse is good.
Read more: https://www.dieselbombers.com/chevy-...#ixzz12onT2iBs
ON what you just tested sound like OPS and LP is working
Could be that OPS is on it way out and remember if you change it out put in AC Delco
Old Oct 19, 2010 | 11:55 AM
yamadude's Avatar
thanks. i plan on using the ac delco when i change it. may try a new ops and see what that does.
Old Oct 19, 2010 | 11:59 AM
Crazy's Avatar
Other thing how old is the oil if has lot miles on it can be getting thin that could make oil psi drop faster and that way you are not hearing the pump run when you shut off
Old Oct 19, 2010 | 08:58 PM
yamadude's Avatar
just changed it about 300 miles ago. used super tech 15/40 and super tech filter with anti drainback valve. from what i have read, it is good stuff.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
