upgrade
Old Oct 18, 2010 | 06:21 PM
olsmokie47's Avatar
Default upgrade
ok all im planing on doin is changin the fuel pin and pod injectors. now do i need new head studs just for that
Old Oct 18, 2010 | 06:31 PM
JBradley500's Avatar
doubt it... what have you done to your injection pump? and what year is your truck? i wouldnt change injectors if your truck is non-intercooled.
Old Oct 18, 2010 | 06:32 PM
RSWORDS's Avatar
No you will be fine. MIght need some air and a timing bump to really use those POD's. In all reallity with your non-I/Ced injestors I woudl not waste your money on POD's.
Old Oct 18, 2010 | 06:40 PM
olsmokie47's Avatar
just turnd the fuel pin and the thand that goes around the fuel pin one complet turn and thats when i broke the banjo bolt so idk what it will do now untill i get that bolt
how do i turn the fuel up?
Last edited by olsmokie47; Oct 18, 2010 at 06:40 PM. Reason: Automerged Doublepost
Old Oct 18, 2010 | 07:21 PM
RSWORDS's Avatar
Look in the sticky at the top of the 1st gen section page.
Old Oct 19, 2010 | 11:39 AM
Levi Miller's Avatar
i would deff get guages before you do any of that you need to be able to monitor everything and a fuel pin from mnh is 105 and a 3200rpm gov spring 25 bucks you will gain the most power with those to things you can make plenty of power without injectors all of the parts i have in my truck i hadnt put in a gov spring in till about a month ago and i didnt realize how much it actualy helped me on power levels and fuel economy you can buy injectors butt i would get guages a gov spring and a fuel pin and go from there you will be supprised on the power you will gain from spendin just 130 bucks and if you do wind up getting injectors i agree with rswords spend a little extra money and get a good set of injectors but hey everone is different good luck man
Old Oct 19, 2010 | 12:12 PM
big bad diesel 416's Avatar
Site Sponsor
ya man gauges first then the rest as far as PODS for what ya can get those for you can get a set of SDX injectors some of the best cummins injectors on the market they will smoke less and run cooler while giving you some great HP
Old Oct 19, 2010 | 05:44 PM
RSWORDS's Avatar
Besides, a POD is not much larger then stock and has a worse spray pattern.
Old Oct 19, 2010 | 06:58 PM
olsmokie47's Avatar
yea im gonna stick to the minimal untill winter is over cuz i gota hual fire wood with it but yea just fuel pin and gov spring and a new turbo housing with a wastegate
Old Oct 19, 2010 | 08:04 PM
kieron_kohlmann's Avatar
SDX is the way to go. Very satisfied with mine!
