homemade TM
Old Oct 18, 2010 | 05:08 PM
muderxtreme's Avatar
Default homemade TM
crazy suggested i post this on here so here ya go. i used 1/8th in aluminum plate that i had laying around. A spring, eye bolt and vacuum cap from the local hardware store. i took the factory boost actuator off and marked and drilled the holes from the original mounting holes. i had to trim the plate to fit the curved part of the turbo. then drilled a hole for the eye bolt to pass through. i slipped the open end of the spring onto the actuator lever and the other end on the eye bolt. then put the nut on and tightened it to have a little bit of tension on the spring. i then removed the factory line running from the solenoid to the regulator and capped it off with the vacuum cap. i wouldn't recommend doing this with out a boost gauge. i had to buy a couple different springs to get the boost level right. with each spring i have about a 4psi range of adjustment. right now its set at 11psi of boost wot.
Attached Thumbnails homemade TM-regulator.jpg   homemade TM-regulator2.jpg   homemade TM-regulator3.jpg
Old Nov 19, 2010 | 06:18 PM
pipelayer4777's Avatar
That is a great idea, could I get you to email me these pics so I can see them in a little better quality. I also would like to know what springs you tried and what the results were. justinatstormconstruction@yahoo.com
Old Nov 19, 2010 | 10:05 PM
Crazy's Avatar
i am sorry that couldn't gave you spring psi
Old Nov 20, 2010 | 08:52 PM
mud's Avatar
mud
crazy send me some picks to my email chevy6.5tdguy@yahoo.com
Old Nov 20, 2010 | 11:09 PM
Crazy's Avatar
muderxtreme glad it work for you
Maybe you gave Mud the sping #ers sent he have the same yr truck
