82 chevy with 6.2
Old Oct 18, 2010 | 08:46 AM
82Chevy6.2L's Avatar
Default 82 chevy with 6.2
i have an 82 chevy with a 6.2 diesel. I went to replace the started and the bolt holes were drilled out by the previous owner. any suggestions on what to do with it? I don't know if i should leave it or not.
Old Oct 18, 2010 | 10:53 AM
Crazy's Avatar
will the bolts fit the new starter if not i would guess the last owner had some problems with old starter and went to bigger size bolt and you may have drill new stater to fix. I know these starter have given some problems with bolts breaking and stripping out if you don't have front bracket and also when putting new starter in replaces the bolts and torque bolts to 40 ft. lbs.
Let us know how make out
Old Oct 18, 2010 | 11:00 AM
another problem I came across was when i tried putting the starter back on with the bigger bolts they wouldn't thread. I wasn't sure what the best thing to do was.
Old Oct 18, 2010 | 11:06 AM
Crazy's Avatar
are they the bolts you pull out old starter or did try putting bigger ones in
These are part #er for boltes
OEM (starter bolt): 15544950
Advance Auto (starter bolt): 72181
Old Oct 18, 2010 | 11:07 AM
they are the bolts i pulled out of the starter when i was replacing it
Old Oct 18, 2010 | 11:11 AM
Crazy's Avatar
and now you are saying they won't fit the threads
Old Oct 18, 2010 | 11:14 AM
they fit into the starter but wont thread into the flywheel housing, i dont want mess with the housing and end up messing up the holes more than they already are.
Old Oct 18, 2010 | 11:19 AM
Crazy's Avatar
ok let see got this right you are saying the new starter you got has bigger holes if that so it may be the wrong starter
Sorry if am miss under standing you i been up all night just tired so bear with me help you best i can
Old Oct 18, 2010 | 11:25 AM
i had the cone from the old starter put on the new starter. its the right one the bolts fit the starter fine but wont thread into the flywheel housing at all. the holes arent stripped out and its the same bolts i took out from the old starter. so im thinking the flywheel housing is messed up but i didnt want to retap the holes and mess it up worse.
Old Oct 18, 2010 | 11:31 AM
Crazy's Avatar
check make sure the bolts ain't bent
do bolts thread in with out starter
