Trouble codes help
Old Oct 17, 2010 | 09:49 PM
navy_welder's Avatar
Default Trouble codes help
I justput a new ip in my truck and it gives me new codes and won't start I have a fass 95gph pump that was installed maybe 3 months ago and my truck is giving me p0230, p0237, p0380,p0382 and p1693.... Please help
Old Oct 17, 2010 | 09:56 PM
RAW's Avatar
RAW
P0230 Fuel Pump Primary Circuit
P0237 Turbo Charge Boost Sensor A Circuit Low
P0380 Glow Plug/Heater Circuit A
P0382 Glow Plug/Heater Circuit B
P1693, Companion Code, meaning there is a code in another controller.
When you bump the starter, can you hear the fuel pump running?
Old Oct 17, 2010 | 10:17 PM
And 1689and 0122
Yes at 16psi I have a gauge and the injectors are fully primed but something isn't letting it fire
And it gave me the 1689and 1693 before I changed the ip
Now it won't even fire its sounds like something is stopping it from firing cause like I said there is fuel squirting out of the lines when I crank it but as soon as I seal and try to start it just won't
Is how it started is that it gave me a cs code and I changed the cs sensor then it was fine then on my way to work I was driving and the pedal was to the floor and only going 70 then it backed fuel down and put me in limp mode and 45 spitting and sputtering is all I could get and it gave me those codes and the cs code again and now I have the new ip and the cs code is gone but the others are still there so the ip is reading it's just something else stopping it from running
Last edited by navy_welder; Oct 17, 2010 at 10:17 PM. Reason: Automerged Doublepost
Old Oct 18, 2010 | 07:55 AM
RAW's Avatar
RAW
P1689 is no Communication between the ECM and Injection pump. Double check all fuses, relays, and all connections and wires on the left side of the engine. Your truck may need a trip to the dealership for a scan if you can't find anything obvious.
Old Oct 22, 2010 | 02:47 PM
jkidd's Avatar
1689 can be corrected by swapping the fuel system relay with another in your fuse panel. p0122 is a TPS.
Are your batteries good? seems like a lot of codes all at once? Give me a call if you need some help.
Old Oct 23, 2010 | 01:38 AM
dukeboy_318's Avatar
if you have a box, take it off completely, harness and all, mine did the exact same thing with similar codes when my edge juice fried itself. if that doesnt fix it, double check and make sure you dont have a ground wire that was left un hooked and changing the IP
asajay
Sep 10, 2015 12:08 AM
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
DSM1988
Jan 18, 2015 11:11 AM
Altonlee
9
Oct 8, 2014 02:31 PM
