fuel pressure reference
Old Oct 17, 2010 | 07:17 PM
Jeff M's Avatar
Default fuel pressure reference
where is everyone referencing fuel from after installing the aird dog 150? right now get fuel pressure from the schader valve on the stock fuel line at the vp44.
Old Oct 17, 2010 | 07:35 PM
RAW's Avatar
RAW
I think most people get it right off the supply line Banjo bolt. It's the closest to the VP44 you can take the pressure.
Old Oct 17, 2010 | 07:38 PM
24vmatt's Avatar
X2
Old Oct 18, 2010 | 02:03 PM
Jeff M's Avatar
does that banjo bolt come with the AD150 kit? or if not where can i get one?
bump
Old Oct 18, 2010 | 03:29 PM
Here is the one I was telling you about earlier.
push lock
Old Oct 18, 2010 | 07:03 PM
Jeff M's Avatar
exellent! then i would need a union to for that to screw into the vp44 right?
Old Oct 18, 2010 | 07:08 PM
not quite - the fuel pressure reference comes from the 1/8" npt port on that 90. And you should already have the fitting to go into the VP-44.
Old Oct 18, 2010 | 09:27 PM
Jeff M's Avatar
I know the fuel pressure comes from the 1/8" port. I was referring to how to connect that fittiing to the vp44. Im pretty sure the current fitting on there is a banjo bolt.
would this ben the one i need to connect between the vp44 and the 90* 1/2 fitting?
http://www.vulcanperformance.com/1-4...-p/08orb08.htm
Old Oct 18, 2010 | 10:19 PM
RAW's Avatar
RAW
This is what you want:
BANJO BOLT - TAPPED ('98.5-'09, 5.9L & 6.7L) DODGE-Dodge Cummins Diesel Truck Accessories Geno? Garage
Then thread your pressure sensor into it.
Old Oct 18, 2010 | 10:28 PM
Jeff M's Avatar
Originally Posted by RAWilliams
you do know that i am getting an AD150 right. if i get the AD i will have to use a JIC 90* fitting to go into the vp therefore i wont need the banjo bolt right?
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
