white/grayish smoke from exhaust after new turbo
Old Oct 17, 2010 | 05:12 PM
InsertNameHere's Avatar
Default white/grayish smoke from exhaust after new turbo
well i replaced my turbo due to a bad oil seal in the turbo, and i upgraded the oil drain tube as well. the oil drain was installed following the International install directions.
now while the truck is idling i dont produce any smoke. but i do have white smoke coming from exhaust when i get into boost (5lbs @ about 1500+ rpm's). after i let off the throttle i get smoke coming from underneath the turbo. could this be coming from the oil drain?
when i have the truck in park, i get the engine up to 2000 rpm's and it doesn't produce any smoke at all. nothing from underneath the turbo or the exhaust.
i'm also getting a "hissing" sound coming from the engine while its idling, i cant tell if it goes away when rpm's increase due to engine noise. could this be a boost leak?
does anyone have any ideas on a possible solution to my problem?
the factory turbo was replaced with a brand new Garrett Powermax turbo.
Old Oct 17, 2010 | 05:20 PM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
First off the smoke could be from built up oil in the exhaust from the old turbo burning off.
Its easy to get the up-pipe clamp on but the up-pipe flange not quite aligned and it will leak exhaust.
Old Oct 17, 2010 | 06:23 PM
i would agree 100% with you on that. but the part that me baffled is the after i get off the pedal the smoke i can see coming from the bottom of the turbo. could the exhaust leak let some of the smoke come back up through the y-pipe? could that be why i am seeing some white smoke coming from under the turbo after i get off the gas? is there a easier way the make sure i get the y-pipe aligned correctly?
Old Oct 18, 2010 | 09:10 AM
Mdub707's Avatar
When you get off the throttle, if you have boost built up, it needs to go somewhere, and when you let off it wont go into the engine, it goes back to where it was coming from. Ever hear of turbo-fart? That's what is happening.
Old Oct 18, 2010 | 09:51 AM
Jagsdiesel's Avatar
A turbo bark on a 6.0 with a VGT turbo is a poping sound. No smoke will be see.
Loosen the up-pipes from the manifolds. You'll need a 10mm wrench and a 13mm swivel socket. Then loosen the clamp at the turbo. With a flash light make sure the ypipe flange falls into the pocket on the turbo side. Once it fits snug tighten the ypipe clamp and then tighten the manifold connections back up and you should be good to go.
Last edited by Jagsdiesel; Oct 18, 2010 at 09:51 AM. Reason: Automerged Doublepost
Old Oct 18, 2010 | 10:59 AM
Mdub707's Avatar
I agree. I was thinking that he may have normal turbo fart/bark, with other issues at the same time, thus the smoke.
Pull the EGR valve and look inside the intake manifold, does it look wet?
Old Oct 21, 2010 | 05:58 PM
i managed to get a quick pic of the y pipe to the turbo. what do you guys think? could be the source of the hissing noise i hear?
sorry the pic awkward looking i used my phone for the picture.
Old Oct 22, 2010 | 08:49 AM
Mdub707's Avatar
Yeah, looks like the clamp isn't on there correctly!!!
Old Oct 22, 2010 | 03:41 PM
i loosened the clamp to look and see if the y pipe and the turbo were aligned but i can't tell really though.
Old Oct 22, 2010 | 07:48 PM
Mdub707's Avatar
The clamp is what lines everything up and holds it tight together. They're designed that way, the V-band clamps. It will be really noticeable if it's not lined up, it will hiss like crazy.
