Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
need help findin information
Old Oct 17, 2010 | 07:50 AM
oleskied2005's Avatar
Default need help findin information
im lookin for the different classes and there regulations im tryin to get everything set up for next year season. i want the truck to be streetable it is my daily driver and i do pull trailers around 12k a lot.
Old Oct 17, 2010 | 07:56 AM
J-Pipes's Avatar
Try checking out the sister forum, truckpuller.com. There should be a link to it in my sig, just scroll down to the appropriate class and I believe that inside each thread they have the NADM rules posted. Should get you started in the right direction, but rules may very for local pulls. Good luck with the truck, it's alot of fun
Old Oct 17, 2010 | 11:57 AM
James_M's Avatar
In the classes where it says you must put two 3/8 bolts as close to the turbo as possible, do they mean the down pipe? Or can you put them after the bend.
Old Oct 17, 2010 | 04:44 PM
cummin_un_glued's Avatar
FormerVendor
most places want the cross bolts within 12" of the turbo outlet
Old Oct 17, 2010 | 04:56 PM
James_M's Avatar
When it says all vehicles must be equipped to direct exhaust upwards, does this mean stacks?
Also, does sled pulling have any negative effects on the steering? Can it cause A bad alignment?
Sep 9, 2015 09:00 PM
