0-60 times
Old Oct 16, 2010 | 09:51 PM
dalton06's Avatar
Default 0-60 times
I got bored and have been playing with 0-60 times on monitor. I was just wondering if anyone else has some times? I've only got non boosted numbers so far and didn't get extreme setting. Try to get more soon.
Non boosted takeoff
Stock setting- 9.33
Tow - 8.47
Performance - 7.76
Old Oct 17, 2010 | 10:16 AM
bullfrog8813's Avatar
Do boosted 4wd... ull see a lot better times... as long as ur not doin like 30lbs when u leave u shouldn't tear anything up I do miss that feature on my edge... now I just take into consideration that a subaru wrx does like 5 sec 0-60 (give or take) and I'm faster of course on a closed track with professional drivers
Old Oct 17, 2010 | 12:08 PM
jramon85's Avatar
6.7 sec edge on 5 (no hot unlock)
Old Oct 17, 2010 | 04:47 PM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
Around 2 seconds. At least I know my 60' times at the track are 1.51@ 54mph.
Yes do a fourwheel launch, start at 10 psi boost and if the ires hold go higher. I leave around 35 to 40 depending on track conditions.
Old Oct 26, 2010 | 05:53 PM
dalton06's Avatar
Dang. Sounds like I got some work to do. I've been debating about 4wd but just been scared. At what point do u flip back to 2wd? Does it depend on speed or just when u get going?
Old Nov 4, 2010 | 02:18 AM
dalton06's Avatar
Anyone?
Old Nov 4, 2010 | 08:48 AM
Jagsdiesel's Avatar
I do fourwheel burnouts in the burn out box. Than fourwheel launch and fourwheel all the way down the track. You can switch it out of four if you want but unless you lift off the throttle its going to stay.
To get over the fear of breaking lock it in four and roll up to the starting point that way the t-case and front diff are tight and ready. The guys that come up to the starting point flip the fourwheel drive switch/or throw the lever, than boost and launch are the ones that send chains through the case. I can honestly say my t-case has never been opened up.
Old Nov 4, 2010 | 12:49 PM
CreeperSleeper's Avatar
Yep, shift out of 4wd once you are coasting.
gunman41mag
The Sportsmen's Lounge
Jul 23, 2015 11:35 AM
InheritedDiesel
Apr 14, 2015 10:41 PM
InheritedDiesel
Apr 12, 2015 04:35 AM
Ryans71
Diesel Engine Conversions
Mar 7, 2015 09:38 PM
boosthappy
Nov 2, 2014 11:16 AM
