smoke and leak
Old Oct 16, 2010 | 08:21 PM
diesel57's Avatar
Default smoke and leak
I have an 89 12 valve in a 99 ford f-350, smoking real bad all the time, blue smoke not oil smells like fuel, I have this engine inner cooled, is it ok to do this with an engine not originally inner cooled? inj. pump is also leaking. thanks
Old Oct 16, 2010 | 08:31 PM
6btDakota's Avatar
fix the leak first its probably letting air in too. where is the leak at?
Old Oct 17, 2010 | 11:11 AM
RSWORDS's Avatar
timing?
Old Oct 17, 2010 | 07:52 PM
diesel57's Avatar
the leak is between the back two bodies on the inj. pump It has been leaking off and on for a while. my concern is will this non inner cooled pump be alright running an inner cooler. I am going to fix the pump, but was'nt shore if I needed a pump off of 2nd gen 12v. Also I found a pump off of a stationary cummins . Will it work? thanks
Old Oct 17, 2010 | 08:23 PM
Rusty89Cummins's Avatar
your cylinder head could be cracked where the the injectors come in next to the valves. i just blew my head gasket and when i got it all apart i found out i had 6 cracks on 1-5 cylinders and the #2 cylinder had a crack going to both the intake and exhaust valve which i belive caused the valves on that cylinder to pit all to hell. my truck for a while had alot of blue smoke so i think thats wat did it. thats just my imput though.
Old Oct 17, 2010 | 08:28 PM
RSWORDS's Avatar
I dare you to find a 1st gen 9mm head w/o cracks... you wont. They don't hurt anything and are perfectly normal.
Old Oct 17, 2010 | 09:01 PM
huh. figured cracks wouldnt be a good thing.
Old Oct 18, 2010 | 04:01 PM
RSWORDS's Avatar
If they are gapping holes then yes. If just a hairline they are fine, VERY common.
mattshow123
14
Mar 12, 2018 01:41 PM
Mike0885
Feb 28, 2015 03:16 PM
zoomer10h
Ford Powerstroke 08-10 6.4L
Feb 6, 2015 01:38 AM
bypass-21
Dec 16, 2014 08:23 AM
