please please please help! backfiring than killed
Old Oct 15, 2010 | 03:03 PM
koleby's Avatar
Default please please please help! backfiring than killed
k so driving my truck an it started to lose power everytime i hit about 30 and 40. then the day after i started it up and was driving and it started backfiring with some white smoke. wasnt doing it too bad just when i got on the throttle. by the end of the night on my drive home it would backfire everytime i stepped on the gas and i had to keep a little throttle on at stop lights or it would die. didnt let it till i got home but when i did it died before i even parked it. now she wont start.. is it my lifter pump maybe? please any and every comment people have please post i need help
Old Oct 15, 2010 | 05:57 PM
901stgen's Avatar
Its something with your fueling. My grandpas 24v does the same thing. Lift pump would be my guess.
Old Oct 15, 2010 | 06:10 PM
JBradley500's Avatar
im just going to ask, have you changed the fuel filter?
Old Oct 15, 2010 | 06:33 PM
Begle1's Avatar
Could be an air leak, could be a fuel supply problem, could be a broken spring inside the injection pump.
Old Oct 15, 2010 | 08:19 PM
RSWORDS's Avatar
I'd start with a fuel supply issue... Either a leak, pressure problem, or obstruction. Could also be a bad fuel issue... When did you fill up last? Change your filter and see if it runs better.
Dergeist
Jan 22, 2015 06:34 PM
