weak 12 valve
alright boys i have 98 12 valve 4k gsk twin turbos top turbo is 12/62/68 bottom is a ht3b with a 26cm ex. housing. 100 plate full foward tuned afc.timming at 14.5* head studs and i just put in a set of 5x.014 injectors from sdx this truck is still weak and cant figure this one out need help
Look hard at the transmission too. You can have all the power in the world, but if you cant put it to the ground its useless.
Boost leak tester:
https://www.dieselbombers.com/5-9l-2...ak-tester.html
https://www.dieselbombers.com/24-val...ke-system.html
https://www.dieselbombers.com/dodge-...tructions.html
Boost leak tester:
his exhaust housings are fine, there is always the chance your cam is retarded a few degrees which will ruin performance. i have seen this happen to stock trucks built from the factory its the main reason why some trucks just seem to run better than others. good luck figuring it out
