Heated Mirrors
Old Oct 15, 2010 | 02:00 PM
springer's Avatar
Default Heated Mirrors
My heated mirrors on my 01 dont work any more. Is this a common problem? Is there a fix for it? Does any one know what happens to them?
Thanks
Old Oct 15, 2010 | 02:56 PM
tiremann9669's Avatar
Fuse ? switch ? I wouldn't think both elements burned out at the same time.
Old Oct 15, 2010 | 03:00 PM
crzycummins's Avatar
thats a good point
Old Oct 16, 2010 | 12:21 PM
01trailerpuller's Avatar
If you check those and they are good. Pull off one the mirrors and put a volt meter on it and verify it is getting power.
Old Oct 19, 2010 | 08:58 PM
springer's Avatar
Can you take the glass out of the housing so I can test it right at the element? The switch lights up and I can hear what sounds like a relay clincking so I am assuming that the switch and fuse is fine.
Old Oct 19, 2010 | 09:04 PM
RAW's Avatar
RAW
I know my right mirror has not heat to it. It is the element as well. I'm planning on getting heated tow mirrors in the future, so I am not making any repairs at this time.
Old Oct 23, 2010 | 06:20 PM
Russ Roth's Avatar
Both mine quit working a couple years ago. New mirror glass on both sides and that solved it. You can replace them by prying very gently near the center of the mirror so you don't break them. Both of mine came out with no cracks or breaks. The new glass snaps back in place but you need to make sure they are snapped all the way in.
