gauge problems.....?
Old Oct 14, 2010 | 10:24 PM
99dodgecummins's Avatar
Question gauge problems.....?
Neither my odometer or speedometer will work, They worked after the conversion and when i took it to the shop they said something about the pcm or ecu? They told me that, "this was a common problem with the 12v cummins turbo diesels". Please help me figure this out....?
Old Oct 15, 2010 | 08:45 AM
zjohnsonua's Avatar
have you checked the speedometer gear?
Old Oct 15, 2010 | 01:37 PM
elledge12's Avatar
If your truck has the 99 everything but the motor and tranny your problem is the ABS sensor on top of the pumpkin on your rear end. its a common problem on the 1998.5-02 trucks. if you search this in the 24 valve section you will find info on it. the sensor on my 2000 cummins went out twice in the time i had it.
Old Oct 17, 2010 | 01:30 PM
no my truck is a 99 but everything was pulled from a 97 Cummins.... speedometer gear? where is that located? would that cause both of the gauges to not work? hopefully this answers your questions and thank you.
Dbleo351
Nov 20, 2016 09:34 AM
Steve123
Sep 28, 2015 02:36 PM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
scottxmorris
Oct 8, 2014 02:14 PM
