vgt turbo on a 12valve
Old Oct 14, 2010 | 05:40 PM
ztk7220's Avatar
Default vgt turbo on a 12valve
just wondering if it is worth it or if it even works to run a vgt turbo any more info about them would be awsome
Old Oct 15, 2010 | 01:58 PM
85_305's Avatar
Being Evaluated
It will take a hell of an expensive turbo, and a LOT of electronics to run it. The vnt on my Volkswagen is controlled by the ecu as well as by boost and vacuum. It's rather complicated, and since the 12v is 100% pure mechanical, I wouldn't hold my breath to it being a worthwhile swap.
Old Oct 15, 2010 | 04:53 PM
FastCR's Avatar
somebody on compD has done it, running the VGT with a wastegate actuator. Working well for him I believe.
Old Oct 15, 2010 | 05:58 PM
cumminspwr11's Avatar
ya it works out real good on the 12valves, you have to use a wastegate actuator as state above to control the vains, and do some custom intercooler pumping and down pipe, i have also seen a guy running a 07 5.9 cr turbo with good luck on his 95
Old Oct 15, 2010 | 06:43 PM
85_305's Avatar
Being Evaluated
Yes the vnt mechanism is controlled by a wastegate actutator.. i'm not sure how the electronic portion is done though on a 12v? How would the ecu control everything if there isn't an ecu to begin with?
Old Oct 16, 2010 | 12:53 PM
dan33klein's Avatar
hense, "the waste gate accuator" there is no electrons, when the truck builds boost, the wastegate accuator opens the vanes to increase the exhaust housing size.
Old Oct 16, 2010 | 12:58 PM
85_305's Avatar
Being Evaluated
I figured you would be spouting off, jacka$$. Long time no speak.. you lose my number?
I'm no turbo expert, but at least on my volkswagen, the wg controlls when to begin opening to dump excess boost, and when to initiate the vnt (you can control the vnt opening points by toying with the ecu and the waste gate). So are you saying you can totally bypass the ecu and run it solely on boost/vacuum, in the case of a 12v truck?
Old Oct 16, 2010 | 06:58 PM
ztk7220's Avatar
on ebay there is vgt turbos for $300 off a 6.7 so the turbo it self are not that expencive how much boost would they push anyone know
Old Oct 16, 2010 | 07:21 PM
bobcat67's Avatar
it's not so much about psi, volume is what is important, but i'd say they'd push 40 psi depending on fueling, i've heard of guys hitting just a notch above 50psi on he351's so i'm assuming the he351vgt would be capable of the same thing
Old Oct 16, 2010 | 07:55 PM
85_305's Avatar
Being Evaluated
Sorry buddy but your on crack. A 200k mile garett vnt15 (oem) for my 1.9 liter volkswagen costs 5-600$ used and around 12-1500 new.
2008-2010 Ford Powerstroke 6.4 Turbochargers Turbo : eBay Motors (item 270646191201 end time Nov-06-10 17:53:50 PDT)
$2,000 for a 6.4 vgt turbo
EDIT: And thats a reman apparently... not brand new.
