12 valve monitor computer
Old Oct 14, 2010 | 08:10 AM
Heavy Smoker's Avatar
Default 12 valve monitor computer
I was wondering if there were any brands out there that have a computer module to change shift points, monitor boost, fuel pressure and egts all on an obd2 12v I think somthing like this would help a 12v big time.
Old Oct 14, 2010 | 12:33 PM
Pyro690's Avatar
Um if you want to monitor something on a 12v'er, put a gauge on it. If you want to press buttons and change your truck, buy an electronic truck.
Old Oct 14, 2010 | 02:19 PM
cumminspwr11's Avatar
arent the 47re trans electrically controled? i know you can buy a box to control lock up but idk about the other shifts
Old Oct 17, 2010 | 12:12 AM
Oh i know i cant plug and play but instead of buying gauges id rather spend less money for somthing i can monitor and change shift points.
Old Oct 17, 2010 | 12:18 AM
The computer on a 12V is very rudimentary - it doesnt have the capability to do what you want to do. Different story on a 24V.
Old Oct 17, 2010 | 02:35 AM
jwirth's Avatar
Shift points are still changed by the kickdown cable on the 47re. the only big diff. with that trans is the governor is not mechaniclly controlled like the 46RH trans. And it's torque rating. Not a good Idea to go adjusting on that cable you go to far with it you can burn up the trans. And if it is adjusted correct and the trans in working correct why are you wanting to change shift points?
Old Oct 17, 2010 | 07:56 PM
have her change at a higher rpm with gov springs.
Old Oct 17, 2010 | 09:40 PM
12valvetater's Avatar
Valve body
Old Oct 18, 2010 | 08:01 AM
I'd have to look into that. Right now im just goona drive her into the ground till i have money. The t/c wont unlock but ill just drive it till it breaks i guess
Old Oct 18, 2010 | 08:45 AM
redrocket9793's Avatar
12v are all mech. The best u can do is to get a lock up controller for the engine use springs to control rpms
