BulletProofDiesel EGR Cooler (& new oil cooler)
Looks like I'm joining the ranks of those with a failed EGR cooler...
On Sunday night the truck threw the dreaded P0404 code. I noticed no performance issues and no check engine light came on either. On Monday morning, I opened the hood and added a little coolant - it looked a little low but I had some work on the coolant lines that provide heat to the water heater in the camper part of the EarthRoamer so I wasn't too worried (but I was a little worried). I also unplugged the EGR valve and then plugged it back in as I didn't really have time to pull it and check it out.
...and then my worries began...
After a clean start and pulling out the drive and down the street a bit the truck began to blow white smoke (it didn't smell sweet but did burn my eyes) and lost power initially. After I shut down and pulled off the road I looked at the coolant level again but couldn't really tell if anything had changed (it had been running a whopping minute or so - I usually let the coolant temp get to 112 before I pull out - that seems to let the truck have better acceleration...I don't know why). I restarted and more white smoke but I had power, there was the P0404 still so I cleared it. After getting down the road one block there was no more white smoke but there was now black smoke when I pressed the throttle hard like from a stop. I had to fill up the diesel tanks, run a few errands, return a few things, exchange a few things...Columbus Day off. The truck seemed to run fine but still there was that lingering doubt.
On Tuesday AM the truck had no white smoke at start up and I let the engine get a little warm as usual before heading to work 35 miles away. I watched the gauges and while it seemed to have a little higher spread between the EOT/ECT it was only 13 degrees and I was driving 65 over the hilly roads and through some recent construction. At the end of the day though I got the white smoke pulling out of the parking lot and there was that P0404 code again. I made it home and called the only BulletProofDiesel shop in Mississippi.
Acey's Auto in Jackson has taken care of me. I have a good relationship with Watson Ford in Jackson but I really didn't want to replace the Ford EGR cooler with a Ford EGR if I could avoid it. If I had a bit more money I think the Ford oil cooler would be replaced with a BPD oil cooler too but I am getting a BPD EGR cooler and stock oil cooler. I do have a coolant filter and oil bypass already installed. I just changed the oil on Monday too drat!
Looks like that mixed diesel/gas coolant episode finally killed the oil cooler in my truck. When I fixed the error of that event and had the coolant tested it came back with a report of much solder and other contaminants in the relatively new mixed coolant (they just filled the radiator not the whole system with gas engine coolant). My subsequent flush took 15 cycles before it was clear...and it started off muddy green (not from oil - I had it tested).
So...I'll have a BDP EGR cooler and a stock oil cooler with the coolant filter and oil bypass to protect it. The truck is just a bit south of 65,000 miles on the original EGR and oil coolers it seems (according to the OASIS). The EGR valve was replaced in March 2005 before I bought it.
I bought it at 41,000 miles in December 2005 after it returned from a 2 year around the world trip so all things considered I'm impressed. I'd be happier not to have to get the work done (or at least to have some time to do the work myself and cut the cost in half) but like I said earlier - Acey's Auto in Jackson, MS part of the BulletProofDiesel supported repair shops is taking care of me.
Thank you guys!
Jonathan
Thank you guys!
Jonathan
Here's an update...
I pulled an oil sample when I returned from my recent trip through MS, LA, TX, OK, CO, NM, and home. The report showed .26% antifreeze and elevated sodium which the lab noted could be an indicator of trouble.
Obviously I've already identified the likely culprit (fingers crossed) but I want to put a big THANK YOU out to BLACKSTONE LABS for their spectrometal analysis and personalized feedback. I called them up to let them know about my failed EGR cooler so they could validate their suspicions (and maybe help guide me forward with greater precision in the future).
I strongly encourage the use of any oil analysis laboratory. Blackstone lab and Predictive Maintenance Services, Inc. have both provided great support to me. I wasn't able to use Predictive Lab in this case because they are pre-paid and I just haven't replenished the stockage I used to have (I tested before my big trip). Their prices are lower than Blackstone BUT you get the Blackstone bottles for FREE and pay for processing. Each company has great personalized service to keep your truck ZOOMING!
In this case, THANK YOU BLACKSTONE!
JDH
P.S. If I get some photos I'll be sure to share them...mostly I want the guys wrenching for me though not framing!
JDH
Bighouse
Apr 9, 2015 06:51 PM
but hopefully this will fix them for good. Keep us up to date on the progress. Maybe take some pics and post them.
