Pyro/Trans Temp
Old Oct 12, 2010 | 10:34 PM
901stgen's Avatar
Default Pyro/Trans Temp
Now i realize that non i/c 12valves run a little hotter but with the little bit of tweaking I've done on the pump should i be worried about the temp? Since i dont have gauges yet....
Old Oct 13, 2010 | 12:57 AM
deanhinsley1963's Avatar
what tweaking have you done? If you have adj. the fuel screw then you need a pyro.
Old Oct 13, 2010 | 01:13 AM
big bad diesel 416's Avatar
Site Sponsor
The top 4 gauges I sell most for the first gens are 1. Pyro 2. boost 3. boost 4. Trans temp
if you got the room I suggest all 4 then ya can monitor everything
Old Oct 13, 2010 | 02:18 AM
901stgen's Avatar
Three turns on the screw and a quarter turn on the pin. I was checkin your gauges out and ill probably buy from you. Also wantin a tach.
Old Oct 13, 2010 | 08:17 AM
kieron_kohlmann's Avatar
These are my gauges. Top to bottom its fuel pressure,boost,RPM,Pyro. 2 Autometer pods modified to fit. Works pretty good, just got them installed last week so im still adjusting to 2 new ones.
Attached Thumbnails Pyro/Trans Temp-img_0487.jpg
Old Oct 13, 2010 | 11:40 AM
901stgen's Avatar
Where did u get your gauge pods from? I want to make sure i get the right ones when i order them. Im planning on getting boost, pyro, trans temp, and maybe rpm.
Old Oct 13, 2010 | 05:04 PM
autometer pods. i ordered through summit racing.
casper83
23
Jul 27, 2015 01:53 PM
doodieroot
May 10, 2015 11:48 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
emilio2496
8
Jan 13, 2015 05:03 PM
mule97
Dec 12, 2014 05:05 AM
