Ratios?
Old Oct 12, 2010 | 09:30 PM
Possmguts's Avatar
Up Ratios?
Hey all,
Just courious what gear my truck has.
What all do I need for the math?
I wanted to share a little experience I had with my truck that Crazy helped me out on.
First of all.... Thanks Crazy!!
Its a 94 6.5 turbo 3500 king cab long bed dually, with straight back 4" to a 6" tip behind the right side rears. It a low rider with bag helpers in the rear and drop spindles in front.
I could start the truck and it would be fine, but after about 20 minutes of driving, it would go into safe mode with the check engine light on. Sometimes it would just do it while driving, and other times it would just start up in safe mode. I couldn't get a pattern figured out but it seamed to just do it whenever.
When I got the truck (2 weeks ago) it had the PMD problem and would just shut down all the time. I got that fixed and have one mounted behind the front bumper now.
Then the other thing with it going into safe mode came about, so I figured I would start with the LP, but that wasn't it. I found the temp sensor was broke, so I replaced that. I had a code for the OPS, so I replaced that. I found some grounds in the wrong places, so I fixed that. But none of that worked. I did however find a broken vacuum line to the turbo, so I fixed that too.
I was guided (by Crazy ) to adding a relay from the OPS to the LP that prevents it from going into safe mode (involved cutting into the gray and orange wires to the OPS and mounting a relay on the firewall), but allows it it shut down in a crash still with the computer still running it. I also was told to remove the ground for the PMD from the heat plate the old PMD was mounted to and extend it to the front screw on top of the LP. Well one of those two things was what fixed it.
At least I have been 2 full days with it starting and running right.
I have to rely on Crazy to link those instructions here for me.
Thanks Crazy! You saved me allot of time and money because EVERYONE else was telling me the IP was bad..... and thats 1000 bucks or more and a FULL day of work!!
Old Oct 13, 2010 | 10:12 AM
Crazy's Avatar
most 3500 are 4:10 gears
Glad i was able to help you out save you some $$$$$
Old Oct 13, 2010 | 03:38 PM
Possmguts's Avatar
I see they merged my posts.
Wasnt supposed to be the same post, One was a guestion and the other was advice for others on how to fix something.
Old Oct 13, 2010 | 11:19 PM
Woody35's Avatar
see what the rpo codes in the glovebox are GT4= 3.73 and GT5= 4.10
Old Oct 14, 2010 | 09:01 PM
muderxtreme's Avatar
i have a similar problem with my truck going into safe mode, its usually only on the highway. is there a thread on here explaining the safe mode over-ride fix? thanks
Old Oct 14, 2010 | 09:07 PM
Crazy's Avatar
Muderxtreme
I would start new thread and gave what ever codes you are getting
There is no over-ride fix safe mod but to fix it
Old Oct 14, 2010 | 09:09 PM
ah okay thanks. when i read the post above i thought yall were sayin that you could wire it to were the truck wouldnt go into safe mode at all.
Old Oct 15, 2010 | 02:32 PM
Possmguts's Avatar
No .... sorry.... bad explaining I guess.
I never figured out why mine was doing it, but all I know is that when I put the PMD ground on the IP screw and added that relay, It stopped doing it.
Does yours start ok and then do into safe mode after its driven a while?
Momo12valve
12
Oct 18, 2015 04:19 AM
