Cant find cause of shutter
Old Oct 12, 2010 | 08:31 PM
beerlvr's Avatar
Default Cant find cause of shutter
just bought 08 3500 has a shutter felt at 68-72 mph, clears up above and below, balanced and rotated tires, removed front driveshaft, changed steering stabilizer and tie rod on pitman arm, nothing has changed, any ideas???
Old Oct 12, 2010 | 10:50 PM
skinnysfd's Avatar
could be a bad rear u joint,carrier bearing, bent rear drive shaft. My 06 had a really bad shutter and i ended up replacing all the rear u-joints and carrier bearing and the problem has never shown up since. my 05 started to get a shutter like this too and it ended up beign a front wheel u-joint so i replaced em both
Old Oct 13, 2010 | 09:52 AM
Heath's Avatar
Authorized Amsoil Dealer
Damn trucks...mine has this but have to date found no fix. New joints, tires, checked driveshaft. Still nothing. I would think if it was something in the tranny or rear end it would have fallen apart by now? I've driven it 20k+ with the problem. Irritating!!
Old Oct 17, 2010 | 06:28 PM
beerlvr's Avatar
new u- joints in still shuttering, took it to dodge told them they should fix it they re- balanced and road forced the tires still isnt better, now i'm fighting with them since it has 64,000mi. they dont want to touch it.
Old Oct 18, 2010 | 09:56 AM
Heath's Avatar
If I run it up to 75mph and drop it into neutral, it runs smooth as silk, so it only occurs when you are in the gas.
Old Oct 18, 2010 | 10:54 AM
beerlvr's Avatar
i tried that and it still shutters comming back down through 70ish, wish i could figure it out it driving me crazy, dodge said they are looking for a driveshaft to swap in to see if that would fix it.
Old Oct 18, 2010 | 10:55 PM
kmkdiesel's Avatar
read this and hopefully it helps you guys out.
Getting to the Bottom of the 68RFE Shudder w/ TransEngineer's Help - Dodge Cummins Diesel Forum
also if you have the 2 piece drive shaft, swapping it out to the one piece is a big help also if its not tranny related shudder.
Old Oct 19, 2010 | 08:19 AM
beerlvr's Avatar
not sure if that is my problem , my truck is 100% bone stock for now, and it is a 1 piece driveshaft, i just want to figure it out before i do my deletes
Old Oct 19, 2010 | 08:55 AM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
Does it shudder at those speed while crusing or while accelerating and pushing through that speed. We have ran into a lot of torque converter shudder while on the throttle around that speed.
Old Oct 19, 2010 | 08:29 PM
beerlvr's Avatar
both but worse if you just stay at 70, it comes and goes a little, and doesn't start till i get a few miles down the road when everything warms up..
filed a claim with dodge customer service they had me bring it back to dealer they suppost to pay for the repairs, should know in a few days what is causing it.
