Dim Headlights????
Old Oct 12, 2010 | 07:10 PM
Munger177's Avatar
Default Dim Headlights????
My low beams are so dim I can't use them??? I replaced the bulbs to no avail. Has anyone had this problem???
Old Oct 12, 2010 | 07:28 PM
turbo20psi's Avatar
I would check the voltage at the headlight socket to see if you have aleast 12 volts.A 12 volt DC bulb will light up at very low voltage 3 volts and give the dim effect.Thinking it may also be a grounding problem.
Dan7769
17
Nov 9, 2017 06:05 PM
carid
Diesel Bombers Sponsors
Apr 7, 2015 07:30 AM
smokee
Feb 14, 2015 12:09 PM
smokee
Feb 7, 2015 01:27 AM
