6.2l diesel question
Old Oct 12, 2010 | 06:41 PM
92typhoon937's Avatar
Default 6.2l diesel question
do u have to pull the upper intake off to get the fuel lines undone
i want to change the valve cover gaskets they leak pretty bad it looks like and would like to take care of this while the tranny is bein rebuilt
so if u guys know any tricks to doing this let me know thanks in advance
Old Oct 12, 2010 | 07:53 PM
Woody35's Avatar
label each line and port on the injection pump with its cylinder number so you dont spend a couple hours tryong to figure which one is which. try to not bend the lines and you will need to bleed the air out of the system once everything is back together
Old Oct 13, 2010 | 06:39 PM
ok guess this wil be an undertaking in itelf while the trans is getting done
need help can u take thing out that goes where the distributor would without messing ne thing up and does it have to go back in in its exact position?
Last edited by 92typhoon937; Oct 13, 2010 at 06:39 PM. Reason: Automerged Doublepost
Old Oct 13, 2010 | 08:43 PM
2MuchJunk's Avatar
Theres no place on it for a distributor. It's a vacuum pump you can just pull it out and put it back in any way as long as when you put it back in you get it engaged with the oil pump.
Old Oct 13, 2010 | 09:29 PM
BULLFROG1's Avatar
I have always pulled the intake to remove the injector lines. I suppose it could be done without removing the intake. I think it would be a pain though. The problem probably wouldn't be getting them off, but probably getting them back on and torqued.
Old Oct 14, 2010 | 05:48 PM
ok thank you very much
Last edited by 92typhoon937; Oct 14, 2010 at 05:48 PM. Reason: Automerged Doublepost
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 6, 2015 03:20 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
