'99dodge ram 5.9 cummins diesel-truck won't start
Old Oct 12, 2010 | 06:40 PM
wolfhound's Avatar
Default '99dodge ram 5.9 cummins diesel-truck won't start
I have replaced the fuel filter, engine lift pump, bled the lines, I need to know if there is any kind of lift pump in the fuel tank. I cant get any diesel out of the tank.
Old Oct 12, 2010 | 06:57 PM
johnyb59's Avatar
never heard of a 6.9 cummins?
Old Oct 13, 2010 | 12:17 AM
bwskweeker's Avatar
On my 99 there is a fuel sending unit inside the tank. ive heard some have it some dont for some reason. Have you checked your IP to be sure it aint that?
Old Oct 13, 2010 | 07:33 AM
RAW's Avatar
RAW
Try to listen for the lift pump. Turn the key run, then just bump the starter over for a fraction of a second. Do not let the engine start. Your lift pump should run for approximately 30 seconds. Listen for it, if you can hear it running, or feel it running, you have bad electrical or a bad pump. Let us know how that works, and
Old Oct 13, 2010 | 11:28 AM
crzycummins's Avatar
x2... on your truck there should be a collection basket in the tank but no intank pump unless someone else put a pump in the tank after the oem pump went out.
Aug 13, 2015 11:50 AM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
ronstop
Feb 26, 2015 09:48 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
