VP44 / BD lift pump. issues
Old Oct 12, 2010 | 05:13 PM
Gerbs's Avatar
Default VP44 / BD lift pump. issues
My truck has problems starting, put the nose down hill fires up (air leak, I know). I put a edge comp tuner on and was driving home, put my foot into it and let off. Anyways my truck cut out and I cant get it to fire back up. I bled the lines and tried again (no luck). No codes, batteries are new, good grounds (nothing visual). The inj. Pump is not even a year old! Could trying to start it with the air leak for a year and the edge comp with the BD pump fry the inj. pump? Truck was blowing white smoke every time I would start it. I know the BD pump is garbo but I just put it on 1 month ago and I really don't want to spend more money on a airdog! Do I need one to keep up with the edge? Also plan on throwing 100hp injectors in. Any advice would be much appreciated and helpful...
PS - First Cummins and I never want to go back to gasoline!
Old Oct 12, 2010 | 05:23 PM
What kind of fuel pressure do you have when trying to start the truck?
Old Oct 13, 2010 | 07:15 PM
Gerbs's Avatar
Mechanic said pressure to the inj. pump is good. But told me there was a low pressure from lift pump code... I checked the codes before I took it in and found nothing. Starting to think no such code exists and they are just trying to void the warranty on the pump... Any ideas?
Old Oct 13, 2010 | 09:06 PM
We need to know the pressure at wide open throttle.
Very bad idea to run an Edge Comp and injectors without a fuel pressure guage. You have a pyrometer I hope.
Old Oct 14, 2010 | 09:37 PM
Gerbs's Avatar
Hydro pump in inj. pump seized up. just got my autometer gauges today! I was running the edge on the level 1 with the fuel turned down. Think im going to order a airdog and a fuel gauge then injectors. Any ideas on turbo for 100 hp inj's, or will the stock turbo do?
Old Oct 14, 2010 | 09:44 PM
Oh no, youll have too much fuel, imo. A turbo upgrade is in your near future.
Good call on the Airdog.
Old Nov 1, 2010 | 12:08 PM
Cummins Cody's Avatar
I just had to replace my lift pump with a raptor 150 to find out im still getting the dead pedaql but now i atleast have fuel pressure im getting a bout 22psi at idle and around 10 at wot so my next guess is the injection pump and was wondering if i get a new injection pump and a set of 100hp injectors if i would need to purchase nething else to handle them?
Old Nov 1, 2010 | 12:40 PM
Id recommend a Phat Shaft 62 Turbo with 100hp or 150hp Big Dawg Injectors.
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
