crazy situation fuel related ?
Old Oct 11, 2010 | 07:48 PM
kyle davis's Avatar
Default crazy situation fuel related ?
ok had super b turbo on truck hit 25-30psi, then left super b on and added a ht60 turbo for twins hit 35 maybe, took ht60 and put super b on alone and now i hit 35+ psi and now the truck under wop at 30psi cuts out like lack of fuel... any ideas whats goin on?? everything else stayed the same
Old Oct 11, 2010 | 09:15 PM
Turbolvr's Avatar
fuel pressure? codes?
Old Oct 11, 2010 | 09:19 PM
kyle davis's Avatar
i usually run 25 idle and 20-21 down the road and at wop it goes down to 8-10 and no codes its like a new truck... wierd
Old Oct 12, 2010 | 08:51 AM
moparious maximus's Avatar
Does it smoke any at boost? Sounds to me like the bigger turbo isnt spooling, or you just plain dont have enough fuel.
Another possible, is that edge box working right, if it isnt doing its boost fooling then the stock programing will cut fuel in an overboost situation.
Old Oct 12, 2010 | 09:23 AM
Turbolvr's Avatar
check the wire tap and the grounds.
Old Oct 12, 2010 | 06:58 PM
kyle davis's Avatar
ok well the truck is running one turbo now and just started after i went back to one turbo... and i will check it but i think its fuel i played with it more today
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
