A518 limits.
Old Oct 11, 2010 | 12:04 AM
C16 power's Avatar
Default A518 limits.
So I got my OD working, I drive big truck, wife bought a horse trailer in wa and followed me up to get it from ca. Everything went fine till we hooked up 10k lb of trailer. It went to **** quick! Trans started slipping and wouldn't kick down on hills. It's fried now and getting a rebuild, guess the question is what am I limited to pulling with this trans with fresh rebuild and converter?
Old Oct 15, 2010 | 08:28 PM
The_Head's Avatar
I have no source, but I recall someone mentioning that Dodge put the towing limit for a stock A518 at 7,000 pounds.
I was told by my transmission builder that I could tow up to 14,000 lbs. People tow more with first gens and do fine but, I can't imagine doing that.
Old Oct 17, 2010 | 07:06 PM
sshort's Avatar
I'm towing 15k + with a home built 727 trans with mopar performance clutches Goerend converter derail pan with the cooling fins no under bed cooler trans-go shift kit. also drag racing I built it almost 2 years ago & have not had any problems using Valvoline atf-4 synthetic
Old Oct 17, 2010 | 11:54 PM
jwirth's Avatar
Maximum Towing Capacity: 11400 lbs 92 dodge 350 factory spec
& your 92 f350 truck max tow spec was 12500. You should be fine when you get it back. I would not go with a factory convertor, suncoast or BD
Old Oct 20, 2010 | 01:58 AM
C16 power's Avatar
Thanks guys!
Str8sixpack
Feb 28, 2015 11:32 PM
MperryB
Dec 15, 2014 06:14 PM
Ryans71
Diesel Engine Conversions
Dec 6, 2014 10:13 PM
