Changing mods
Old Oct 10, 2010 | 08:34 PM
2000 fummins's Avatar
Default Changing mods
Im gonna be changing my setup up around a lil bit and was looking for some info on the setup im thinking about cause ive been towing alot with the setup i have and it sucks haha, but this is what i wanted to change the injectors i have for a set of sdx 5x.012 and the turbo i was thinking of doing a 60/60/16 or a super b and a three piece manifold but keep everything else the same thats in my sig, thanks
Old Oct 15, 2010 | 04:07 PM
v8440's Avatar
Yeah, you're WAY WAY beyond the capabilities of the stock turbo if your injectors are 250 hp over stock. My opinion is that the 16 cm exhaust housing is a good bit too large for towing. I have a stainless 13cm and wish it would spool faster.
Old Oct 15, 2010 | 05:40 PM
bobcat67's Avatar
yeah i'd recommend something around the 62/65/12 size or maybe a super b special which measures out to a 64/71/14, but i'd stay away from a 16 cm exhaust housing that's huge and might not ever spool and if it did it'd be laggy which is not what you want for towing, at least i wouldn't
Old Oct 15, 2010 | 06:03 PM
cumminspwr11's Avatar
i ran a 18cm hx40 for awhile with just a fuel plate and it pushed 28psi and then i add some 370s to the mix and it went to 32 psi but it was soooo slow spooling now i the 14cm and it works out pretty good
Old Oct 15, 2010 | 09:30 PM
blazier18's Avatar
i got 5x0.012's bosch wat do u got
2004LB7
29
Feb 29, 2016 06:00 PM
Momo12valve
Sep 27, 2015 06:21 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
lb7Garrett
Chevy/GMC Duramax 01-04 LB7
Feb 15, 2015 09:02 PM
rtbcoop
Dec 30, 2014 02:13 AM
