slowly taking longer to start
Old Oct 10, 2010 | 07:46 PM
jesse757's Avatar
Default slowly taking longer to start
ok ..was glad to hav help w the egr delete..now in hav i new problem...it started a week or so ago..i hav had to crank it more n more to get it to start..n today it started up jus fine cold...n got bad wen it was warm...now wont start at all...have noticed the fule pump in the tank running exessivly long n sounds week..the battries are strong n it cranks fine but wont fire at all...any suggestions would help...
Old Oct 11, 2010 | 03:26 PM
Mdub707's Avatar
Pump could be crapping out on you. Could also be a bunch of other things. Any smoke coming out one it fires? What color? No codes? (even if there is no CEL, there may still be codes). Have you had the batteries load tested? That's really the best way to see what they're doing. If the batteries get weak, the FICM sees lower voltages and has issues starting.
Old Oct 12, 2010 | 03:55 AM
pushingmy6.0's Avatar
my truck is doing the samething.. new bats in it.. my fuel gage has been jumping around on me.. say.. i know i have a 1/2 a tank.. then ill jump in it to start it up and the fuel gage gos to full and it sits there intill i shut her down.. or what ever it feels like doing.. it takes some time to fire up and when it dose it sound all weak intill its runin....
Old Oct 13, 2010 | 04:06 PM
jesse757's Avatar
no smoke wen it does fire but wont fire at all now...do i need a special code reader? how much do they cost?...i cn tell im gonna need it with this truck..
Old Oct 14, 2010 | 11:20 AM
MUDSTROKIN''s Avatar
Have your batteries load tested. if they test fine my guess would be you have a leak in your HPO system. since you say it's not starting at all now i'd say your STC fitting has crapped on you
Old Oct 14, 2010 | 06:08 PM
jesse757's Avatar
its not the batteries...it will start wen cold the oil pressure guage shows pressure..then wen warm it wont start n oil guage is dead(no movement)..havent read codes yet..dont hav anything to read em..my standard obdII code reader wont read this truck..so i need to know witch reader will..and how do i diagnose wher the hpo system is leaking .? n wats a stc fitting?..im good w a wrench but a lil dense otherwise..
Last edited by jesse757; Oct 14, 2010 at 06:10 PM. Reason: didnt want the lil face there
Old Oct 14, 2010 | 09:47 PM
Mdub707's Avatar
snap to connect fitting (STC). Quite common on these trucks. Sounds like your problem. It will let the truck start, then once it's warm and the oil thins out, it wont start and it leaks out of the fitting.
Old Oct 14, 2010 | 10:31 PM
jesse757's Avatar
do i need a special tool to disconnect it..? or would a standrd ford line dissconect tool work?..and is it located under the plate under the turbo?....do i replace a line or fitting?...or exactly wat do i do to fix it?.....thanks for your help.
Old Oct 15, 2010 | 10:58 AM
You fo to ford and buy the updated kit(4C3Z-9B246-A) with a new design fitting that doesn't wear out. And yes it's the plate under the turbo, remove the intake, turbo and y pipe, pull the IPR valve out, pull the cover off, take 3 torx bolts out holding pump in, take 2 bolts out of stc fitting that connect it to the branch tube. Remove pump. Replace fitting with updated one. Reassemble as taken out
Old Oct 19, 2010 | 03:52 PM
jesse757's Avatar
thanks.. do you hav any idea wat a ballpark cost of the part would be....
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
