6.2
Old Oct 10, 2010 | 05:05 PM
drtydsl's Avatar
Default 6.2
Guys i started a thread in the four wheeling section along these same lines but anyhow, I'm thinking about buying a off road toy to play in and most are a 84-86 chevy 6.2 powered ex military trucks. What do i need to know about these when I look at these trucks, some start and run and some don't.
Old Oct 10, 2010 | 05:13 PM
Captain Call's Avatar
I wouldn't worry. Just yank the motor and put a good ol 350 in it.
Old Oct 10, 2010 | 07:44 PM
92typhoon937's Avatar
Old Oct 10, 2010 | 09:02 PM
drtydsl's Avatar
well im shooting for one that starts and runs, so if it ends up dying on me and i don't wanna rebuild it then yeah i'll throw a 350 or something in there
Old Oct 10, 2010 | 09:42 PM
2MuchJunk's Avatar
Put a 350 in it! Yea you would be with stupid.
I would not buy one that isn't running you just don't know what you are getting in to. If you can be there to see the truck before you buy it. Make sure to start it when its cold and see how much and how long after it starts it produces white smoke. Some will be expected but it shouldn't smoke you out or stick around for a long time. After it warms up slowly rev the engine to around 2000 rpm let it hang out there for a bit and slowly back off of it. It should be able to do this smoothly and hold a steady rpm. Then everything else is pretty standard excessive blow by, strange knocks, low oil pressure, oil leaks stuff like that.
Old Oct 14, 2010 | 02:52 PM
ChiefRichard's Avatar
Default 6.2's been good to me
I've had my 87 Chevy one ton for a few years now. I live in the country and we have to haul water for a cistern, up steep, country gravel roads. I carry a 1000 gal. tank on a flat bed and filled with water weighs in at nearly 9000 lbs. Engine has never given me any problems. In the summer time I haul water, all over this county, to fill peoples swimming pools. Hot weather or cold, no problem. I love it.
Old Oct 16, 2010 | 12:03 AM
BULLFROG1's Avatar
goona make this short and sweet
These trucks are money pits unless you work on it yourself. Don't buy one unless you are willing to get greasy, and learn about the truck. Pretty much anything that breaks will be 500 dollars or more if you were to take it to a shop.
If this doesn't scare you off, I will give you a list of what to look for....
NSmachine44
Aug 16, 2015 09:25 PM
MIBoondocker
Jun 20, 2015 11:56 PM
jedder21
Mar 7, 2015 09:47 PM
Caveman94
Dec 8, 2014 12:21 PM
jdcarter
Nov 29, 2014 11:31 AM
