injector lines
Old Oct 10, 2010 | 03:08 PM
12valvecory's Avatar
Default injector lines
got the motor with all lines off and have never worked on a rotary and can figure out how the lines hook up to the pump so if you can send me pics or point me in the right direction i would like it alot.
Old Oct 10, 2010 | 06:33 PM
6btDakota's Avatar
I had the same problem. They go around the pump in the firing order. firing order is on the tag on the engine. i forgot it 153624 i think is it. cylinders go from grille to firewall 123456.
also youtube ve governor spring install and the video shows a good pic of the lines with the throttle linkage out of the way.
also they go around the pump counter clockw ise when looking at it from the drivers seat
Old Oct 10, 2010 | 06:57 PM
Billy D's Avatar
That Dakota will be bad *** with a bt6, never seen a Dakota with one
Old Oct 10, 2010 | 07:19 PM
jwirth's Avatar
The lines can only go on one way ???
Old Oct 10, 2010 | 07:38 PM
Mark Nixon's Avatar
They only go on 1 way, but I can start you off.
#1 cylinder is at the bottom of the pump.
Also, #6 cylinder is the LONGEST line of the set.
Stupid thing about this is, if you know what you're doing, you don't even have to dis-assemble the lines from the holder brackets.
You just remove the hold down bolts for the line brackets and they come out in 2 sections, front and rear.
If you remember that the REAR set of lines comes off first, it's a piece of cake to remove them as an assembly.
Another tip:
Removing the rear set of lines FIRST allows access to the rearmost fitting on the pump, which is not accessible otherwise.
Mark.
Old Oct 10, 2010 | 07:58 PM
jwirth's Avatar
WHAT all the fuel lines are the same length if they were not they would not deliever the same amounts of fuel to each cylinder.
Old Oct 10, 2010 | 08:41 PM
stillcummin's Avatar
maybe he means longest after the top bend.I hope
Old Oct 10, 2010 | 08:51 PM
Mark Nixon's Avatar
C'mon, man, be practical.
They HAVE to be longer along a direct line to their respective injector.
Yes, they do have bends and twists, especially the shorter lines, but the ones with LESS aggressive bends, with more straight, smooth sections, are the ones furthest from the injectors.
I also have a theory on the "all lines the same length" wizardry.
Unlike air, a liquid under non-oxygenated (no air in the fuel) pressure doesn't necessarily need an equal volume to dispel the same amount of fuel, because, as we all know, a (non-aerated) liquid cannot be compressed.
In that vein, given no air and the fact that a column of fuel is "solid", regardless of the length of the line, the resulting reaction should be the same, therefore the volume of fuel (liquid) expelled should not be changed.
The pressure rating (Or "Pop" pressure) of the injector, the injectors volume dispersal, plus pressure input of the injection pump is what changes volume at the tip (nozzle) of the injector.
A column of liquid 1 foot long, or 2 feet long is still going to displace the same amount of fuel when it is pressurized, such as an injection system is.
Mark.
Old Oct 10, 2010 | 08:56 PM
jwirth's Avatar
OMG Go check if you don't believe me.
Old Oct 10, 2010 | 09:07 PM
thanks for input i went to a friends and looked at his and ya its gona be a cool truck.
