squealing when shifting
Old Oct 8, 2010 | 11:55 AM
01_cummins's Avatar
Default squealing when shifting
my 6 spd in my 01 is squealing badly when i downshift its sqealing. my tailshaft seal is shot. so it is driaing fluid sometimes. the guy i bought it from probably ran it dry a few different times could this squealing be the tranny finaly going down from all the miss-use? it sqealings from 4th down. 6th to 5th to 4th isn't a problem its 4th to 3rd and down. its geting steadily worse and i need to figure out whats going on. any ideas?
Old Oct 8, 2010 | 12:02 PM
BIG NIG's Avatar
check your exhaust manifold bolts
Old Oct 8, 2010 | 01:00 PM
01_cummins's Avatar
its either right under the cab. or behind it. so i assumed it would be the trannsmission. how would the exhuast manifold bolts affect this?
Old Oct 8, 2010 | 02:20 PM
BIG NIG's Avatar
look at #6, if the bolts start backin out it sounds like a squeel or some high pitch noise
Old Oct 9, 2010 | 12:09 AM
01_cummins's Avatar
ive checked everything out that i can. and it apears to be the t-case. the tranny has oil. and all manifold bolts r tight. i pulled the front drive shaft just to see what might happen and it apeared to get better. but im not exactly sure what that means
Old Oct 9, 2010 | 07:53 AM
RAW's Avatar
RAW
Have you tried the same shift patterns in 4x4?
Max713
Apr 17, 2015 05:41 PM
denpenn
Feb 11, 2015 11:29 PM
metrickjb
Jan 21, 2015 04:16 AM
SixSpeed
Jan 11, 2015 01:41 AM
Alfdude1
Jan 9, 2015 01:19 AM
