What pump???
Old Oct 7, 2010 | 09:51 PM
12valvecory's Avatar
Default What pump???
So I bought a 2002 half ton with a 1991 cummnis in and it needs the pump changed and I found but the guy said that it won't go on his 91 because the last three numbers are 205 is this true or are they all the same thanks.
Old Oct 8, 2010 | 02:26 AM
jwirth's Avatar
Your best bet is call the dodge dealer. Have them check. Dealer connect well have the years that it well fit via the part number.
Old Oct 8, 2010 | 10:00 AM
Mark Nixon's Avatar
Is yours intercooled or non-intercooled? 1991 goes either way.
A 205 pump is an intercooled pump.
An intercooled pump won't interchange with a non-intercooled, because the delivery valve assemblies, where the lines attach, are longer on a non-intercooled.
You can interchange the 2 by swapping the line attachements, but be careful you don't lose the parts underneath them in doing so.
Mark.
Old Oct 11, 2010 | 08:28 PM
so i changed the backs line and huck it all up and bleed all the lines but now i cant get it to start help.
Old Oct 11, 2010 | 08:34 PM
RSWORDS's Avatar
got your 12v to the shut off solenoid?
Old Oct 11, 2010 | 09:27 PM
yes i have the twelve volts im thinking maby its bad the pump had been sitting around for awhile before i installed.
Old Oct 13, 2010 | 07:47 PM
stillcummin's Avatar
are you getting fuel to the injectors?
Old Oct 14, 2010 | 08:32 AM
kieron_kohlmann's Avatar
How did you time this pump if you just found it laying around?
Old Oct 14, 2010 | 10:19 AM
Mark Nixon's Avatar
VE pumps are keyed, and so is the pump gear.
Assuming the gear wasn't removed from the timing case and the timing wasn't altered, it should run if properly bled of air and the solenoid works.
All he'd have to do is rotate the pump shaft around to match where the keyway is and put it on.
Mark.
Old Oct 14, 2010 | 10:26 AM
Begle1's Avatar
It only goes on one way... Unless you smash the key, then it goes on in several different ways, most of which won't run right.
