48RE issues
Old Oct 7, 2010 | 07:36 PM
Redneck GI JOE's Avatar
Default 48RE issues
so i was throwing codes and was told it was the throttle valve actuator. so i replaced it and all was fine for a day. then it went back to taking off slow and having trouble shifting up. occasionally i will be sitting still and it will jolt forwards. still throwing the same codes. anybody have any clue what will fix it.
Old Oct 16, 2010 | 10:15 AM
bullfrog8813's Avatar
Uhh what codes... I've fried about everything possible in a 48 don't think I've ever had codes tho...
Also be a lil more detailed in what its doin... like the shifting up, does it just shift hard or rev higher tha. Normal before shifting? The jolting forward... does it feel as if the converter is trying to lock up? Taking off slow... does it seem to be slipping... does it do that through every gear till lock up or a certain one? How many miles on the converter? Is it the original factory converter? Have you changed the fluid and filter recently... was there a lot of crap in the pan?
Last edited by bullfrog8813; Oct 16, 2010 at 10:15 AM. Reason: Automerged Doublepost
Old Nov 29, 2010 | 05:21 PM
the codes are P1751(Trans Throttle Valve Postition Minimum Range Performance) and P1753 (Trans Throttle Valve Performance). when taking off it revs high then normal then shifts. it takes off slow just in first gear feels like theres hardly any power. i just turned 101,000. its all stock. flushed trans, new filter, no more then the normal crap in the pan. the jolt will learch the truck forward. almost feels like ive been hit from behind
Old Dec 1, 2010 | 08:56 AM
dangerous1965's Avatar
Change the soleniods!
Old Dec 1, 2010 | 04:04 PM
i really dont know anything much about transmissions, so which ones do i need. sorry if i sound ignorant.
Old Dec 1, 2010 | 05:41 PM
Steelslinger's Avatar
He's talking the governor pressure sensor/transducer (also seen listed as trans speed sensor) and the governor pressure solenoid. Just have to drop the pan and they are right next to the filter. Replace both.
Old Dec 2, 2010 | 04:16 AM
awesome thanks guys
Old Dec 3, 2010 | 12:22 AM
mxtuner1's Avatar
And I know it sounds crazy but unhook and clean your battery cables. Leave key in the on position while unhooked to drain down the capacitors. It really works sometimes on getting the computer to read the selenoids again. And btw - whilst changing the selenoids - adjust the bands (easy - remember inch lbs not ft pounds!) and change the filter and fluid. You should be good to go then.
Old Dec 3, 2010 | 08:40 PM
what about the overdrive and lock up solenoid? or will the other 2 do
Old Jan 7, 2011 | 02:38 PM
thanks everyone for the info. i changed the solenoid and the sensor last night and now it was great.
dwmeehan
Jan 29, 2025 12:13 PM
Ric Stokes
Aug 31, 2015 06:58 AM
culp7
14
Jul 20, 2015 10:13 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
