pump diagram
Old Oct 7, 2010 | 12:53 PM
12vpwr's Avatar
Default pump diagram
does any body know of or have pictures of a p7100 digram? if so please share. i would like to know what the internals look like BEFORE i decide to tear into it
Old Oct 7, 2010 | 01:17 PM
shortbusdriver's Avatar
Tearing into it as in the govenor housing or tearing into it as in working on the plate?
Old Oct 7, 2010 | 01:53 PM
12vpwr's Avatar
tearing into it as pulling the pump and taking it apart to see how it works. im pretty sure i have an internal problem in mine and i aint trustin no shop to work on this thing.
Old Oct 7, 2010 | 05:25 PM
motorboat's Avatar
^^^ Listen up 12vpr. whatever this guy tells you, believe. My own opinion is that a novice has no business working the innards of a pump.
Old Oct 7, 2010 | 07:09 PM
Dirt_Diver's Avatar
I wouldnt do it, unless you are bosch certified and have the proper tools for the job. No normal mechanic can attack this job. Because there are very tight tolerances! There was 2 guys up in town, that tore their pump apart and after everything was said and done.The truck didn't run. If i was you, i would probably sent it to BD or shied (spelling) or atleast a well known pump builder. I know theres a place in Salam, VA they rebuild injection pump and bench test them too.(they rebuild pumps from CAT If you need their number, ill give it to you if your interested)
Old Oct 7, 2010 | 08:38 PM
tiremann9669's Avatar
Whats your truck doing ?
Old Oct 10, 2010 | 07:43 AM
12vpwr's Avatar
its got a miss it sounds like. i was going through and cleaning the top half of of the fuel system (injectors, fuel lines and dv's) and i pulled the dv at the back of the pump and i think when i pulled it, i think a little piece of something fell down in there and clogged something up. i ran diesel kleen through it, a few times, and i put a quart of tranny fluid in with the fuel everytime i fill up. nothing. its been doing this for the past 4 or 5 months. but it still runs like a champ. i just lost some power and spool time.
Old Oct 10, 2010 | 11:24 AM
Dirt_Diver's Avatar
Well if its a miss, usually a injector problem. And did you check the fuel pressure on it?
Old Oct 10, 2010 | 11:43 AM
95cumminsguy's Avatar
x2 on the injector problem causing a miss you can check your injectors by cracking the injector nuts, are you sure something fell in there?
Old Oct 10, 2010 | 12:10 PM
I wouldnt even pull a p pump apart to fix it, and I know how it works....
