Vacuum Pump trouble in my 1990 D350
Old Oct 6, 2010 | 10:48 PM
jdsteele's Avatar
Default Vacuum Pump trouble in my 1990 D350
I recently bought a 1990 Dodge D350 dually pickup. When I bought it, it had no power steering or brake assist. I took the vacuum pump off yesterday to realize that the accesory drive gear and the shaft were gone and the housing was full of metal. I was wondering if anyone has a spare vacuum pump they would be willing to sell? Or if they know of where i could get one? I NEED HELP!
Old Oct 7, 2010 | 01:26 PM
kieron_kohlmann's Avatar
Autoparts store
Old Oct 8, 2010 | 09:31 AM
Mark Nixon's Avatar
Originally Posted by jdsteele
...I took the vacuum pump off yesterday to realize that the accesory drive gear and the shaft were gone and the housing was full of metal...
The shaft and gear were GONE?
As in physically "Not There" or just "Bad"?
The early vacuum pump main bodies (the part that's broken on yours) are not available as a full assembly, that I have been able to find.
Just the pods are available new/reman.
The power steering pump is pressed to the vacuum pump, on the pre-'91.5 trucks.
The '89-'91 style pump also has a propensity of doing exactly as yours did, due to the fact that they do not have a reliable means of lubrication.
I have an engine that this happened to and it lost the ball bearings into the gear train and broke the cam.
It was ugly.
I normally recommend using a '91.5-'98 Vac./PS pump to replace the earlier version, which involves adding in the oil pressure line and the '91.5-'93 version of the rear injection pump support bracket.
Modifications to the large accelerator bracket are also needed for the conversion.
Mark.
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
InheritedDiesel
Apr 17, 2015 07:20 PM
DeLuzGN
Mar 17, 2015 08:08 AM
moneypitk5
Feb 12, 2015 11:01 AM
