12 valve wont start!!
Old Oct 6, 2010 | 09:21 PM
blowinsmoke12v's Avatar
Default 12 valve wont start!!
ok so i was just sittin in my truck idling everything was running fine shut it off went to bed come out in the morning and it WONT START....!!! UGGHH why ?!?! truck has air dog system on it has fuel in the tank...sooo where should i start?
Old Oct 7, 2010 | 07:57 AM
daveO's Avatar
Does it turn over?
Old Oct 7, 2010 | 08:21 AM
Pyro690's Avatar
^ If yes, fuel shut off up with key at run?
Old Oct 7, 2010 | 09:08 AM
BAD ASS RAM's Avatar
fuel shut off it did the exact same thing to me last week
Old Oct 7, 2010 | 11:20 PM
zjohnsonua's Avatar
check the shut off solenoid first, then if thats good check your fuses. A couple of em can cause this problem.
Old Oct 10, 2010 | 10:57 AM
THANKS for all the replies...i have had a problem with the shut off solenoid before...but i cracked number 2 injector and it started right up sooo im guessing im losing prime somehow im starting with the fuel filter...then what?
Old Oct 19, 2010 | 10:17 PM
ok well i found out its just that damn fuel shut off solenoid and it just dont pull itself up unless i bump the starter...so for now i just reach in there and pull it up a little ghetto i know
Old Oct 19, 2010 | 11:13 PM
redrocket9793's Avatar
Try putting your plate back in I know some ppl have pump problems after running no plate for a long time
Old Oct 20, 2010 | 09:26 AM
yeah i just dont know which to put in
Old Oct 20, 2010 | 11:21 AM
94 12valve's Avatar
running with no plate will not harm your injection pump
