any1 have parts 2 convert auto to manual tranny?
Old Oct 6, 2010 | 07:57 PM
brian10's Avatar
Default any1 have parts 2 convert auto to manual tranny?
i have a 2000 dodge ram 2500 with a manual tranny i want to convert it to a manual 5spd or 6spd w.e i can get my hands on. i need all parts including pedals and everything. w.e u got let me know or were i can get the parts?
Old Oct 7, 2010 | 09:45 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
You can have all of my auto parts if i can have all of your manual ones! You have to take them out though! LoL. I dont mind the auto but would MUCH rather have a manual on my truck.
Old Oct 7, 2010 | 09:48 PM
brian10's Avatar
no see i have an auto now. i want a manual
Old Oct 7, 2010 | 11:32 PM
Zane's Avatar
Your opening Quote was "i have a 2000 dodge ram 2500 with a manual tranny"
Your Second Line was "i want to convert it to a manual 5spd or 6spd"
Wha Wha What is it Boy, Do You Have A Manual Transmission, Or Do you want a Manual Transmission?
Old Oct 8, 2010 | 08:06 AM
brian10's Avatar
i have an automatic tranny. i want a manual tranny. so i need the manual parts to do the swap. so i want to get ride of the auto
Old Oct 8, 2010 | 08:52 AM
Mark Nixon's Avatar
The 10 million Dollar question is:
2wd or 4wd?
I have a complete NV5600 conversion from an '02 for a 2WD.
I also have most of an NV4500 2WD conversion, but the trans will need rebuilt.
Mark.
Old Oct 8, 2010 | 06:44 PM
brian10's Avatar
no its 4wd. yea this aint easy 2 get parts. ok but do u guys happen to know if 1 i need a new crank shaft 2 match up wit a nv4500 tranny n also do i need 2 put a new pcm in it. basically if i put the tranny in will it start up so i can run it up 2 my buddies 2 have the ecm flashed 2 a manual. no one seems 2 know if unhooking the sensors in the tranny will keep it from runnin?
Old Oct 8, 2010 | 07:45 PM
kazairl's Avatar
I have a steering column out of an 02 manual. No you don't need a new crank or a new bellhousing.
Old Oct 8, 2010 | 11:33 PM
brian10's Avatar
u dont need a new bell housing to convert an automatic to a manual tranny? every1 tells me u do? n does any1 kno if u need 2 do an comp work so u can start it up? or will the pcm still allow it 2 start n run wiit the auto tranny sensors out?
Old Oct 9, 2010 | 01:43 AM
kazairl's Avatar
That's because they don't know and are just guessing. I've done the swap. I know you don't.
It will start and it will run. I'm not sure if it will go into limp mode or not. A whole 20 mph top speed. I've seen threads of people who have swapped manuals into autos without changing PCMs. It is much easier to swap to a manual than an auto. Ask me how I know. I'll see if I can dig the thread up.
Some reading for you.
Auto to manual conversion - Competition Diesel.Com - Bringing The BEST Together
Also, You don't HAVE to have a manual steering column to do the swap. You can drive the pin out of the shift lever and just use it that way. But If you decide to swap steering columns you could sell your auto swap parts to recoup some of your cash. OR since you are going to a manual you can just modify your existing wiring harness without having to swap it out.
If you have a buddy with a Smarty they can reflash your trucks ECM for the manual. IT will run with out it but the fueling tables are slightly different and makes it easier to stall.
