Vac/Power Steering Pump Help
I discovered today that my 01 has a bad oul leak tween the vaccumn and power steering pump
I used to hhave a link to some rebuild info on this but cant find it now
anybody help me out here ????
Cheers,Kevin
Cheers,Kevin
I just found that website ...its the one I was thinkin of thanks man......I ordered up a kit
DODGE RAM CUMMINS DIESEL VACUUM PUMP RESEAL KIT
REPAIRS THE ENGINE OIL LEAK WHERE THE POWER STEERING PUMP JOINS THE VACUUM PUMP.THIS IS A COMMON LEAK AS THE SEAL INSIDE THE VACUUM PUMP AGES.THE SEAL IS EASILY REPLACED WITH A NEW DESIGNED DUAL LIP SEAL SUPPLIED IN THE KIT.ALSO SUPPLIED ARE THE ORINGS THAT GET REPLACED AND THE GASKET THAT GOES BETWEEN THE VACUUM PUMP AND ENGINE BLOCK WHEN GOING BACK TOGEATHER,PVC TOOLS FOR REMOVING AND REPLACING THE SEAL RETAINER AND SEAL AND BOTH WRITTEN INSTRUCTION AND A 30 MINUTE VERY DETAILED DVD OR VHS SHOWING THE SEAL BEING REPLACED TO SIMPLIFY YOUR REPAIR.
( OLDER 3 SECTION PUMPS ARE VERY BASIC AND HAVE DVD INSTRUCTION OR VHS ONLY )
AND,AS THE VIDEO SAYS,IF YOU FIND YOU CAN'T DO THIS SEND ME YOUR PUMP AND I WILL FIX IT FOR FREE!HAVEN'T GOT ONE YET!WE ARE HERE TO ANSWER ANY QUESTIONS 7 DAYS IF WE CAN HELP YOU AND ARE ALLWAYS HAPPY TO.
THANKS!!! PETER GOULD --- 877-FIXNRAMS (877-349-6726)
GOULD GEAR AND ELECTRIC INC.
WAKARUSA,INDIANA 46573 USA
VACUUM PUMP REPAIR KIT..STILL $59.99
AVAILABLE ALSO ON EBAY,"SELLER.. RAMTRANS1
AS ARE ALL OUR PRODUCTS ALSO
FORWARD SECTION COMPLETE WITH SEAL KIT $189.00
FACTORY TYPE REPLACEMENT SEALS OFTEN FAIL TO REPAIR THE OIL LEAK AS THE LEAK IS ALSO CAUSED BY A WEAR LINE CREATED IN THE POWER STEERING SHAFT BY THE ORIGINAL SEAL.THE DESIGN OF THE DUAL LIP SEAL IN THIS KIT USING A DUAL LIP SEAL RATHER THEN A SINGLE ALLOWS THE DUAL LIPS OF THE SEAL TO FIT TO EITHER SIDE OF THE WEAR LINE ON THE POWER STEERING SHAFT AND KEEP DIRT FROM GETTING IN AND OIL FROM GETTING OUT.THE GASKET IS A CUMMINS DIESEL ORIGINAL PART NOT A PAPER GASKET TO INSURE A PERFECT SEAL WHERE THE PUMP BOLTS TO THE ENGINE.
574-862-1392
CELL 574-849-0453
TOLL FREE 877-FIXNRAMS 877-349-6726
574-862-1392
CELL 574-849-0453
