My heats not as warm as it was last year
Old Oct 6, 2010 | 07:12 AM
Billy D's Avatar
Default My heats not as warm as it was last year
My heat in Goldie doesnt seem to be as hot at all. I re-cored my radiator, new coolant, Cummins T-stat, hoses, and its just not hot. It's warm, any suggestions on wtf's wrong? Do I have to much antifreeze maybe?? Goldie NEVER runs hot, runs real cool, I gota have some heat, winters knocking on my door. I even been pugging it in since it's getting around 50 or so, because that should give me some instant heat, shouldn't it?? Nothing, luke warm heat. What's up??? I need heat!!!
Old Oct 6, 2010 | 08:03 AM
kieron_kohlmann's Avatar
Did you burp the system after you did all that coolant work?
Old Oct 6, 2010 | 11:03 AM
Billy D's Avatar
Yep, did the burp thing. Theres no air in the system. I did that work at the begining of the summer. I got no leaks inside or out, It's never low.
Old Oct 6, 2010 | 12:47 PM
On mine there is a little vacuum diaphragm thing on the heater hoses in the engine compartment. Its on the 2 parallel line that run into the firewall. I dont know what its for but im thinking when you turn on heat it opens a valve and allows hot coolant to go into the heater core. Id check that out. Im not sure if thats its function but it sounds logical.
sorry i found a TSB for your problem. i hope this link works.
https://files.me.com/kieronkohlmann/gtmowg
Last edited by kieron_kohlmann; Oct 6, 2010 at 12:47 PM. Reason: Automerged Doublepost
Old Oct 6, 2010 | 03:22 PM
Rusty89Cummins's Avatar
if you engine warms up to normal running temp than it could be your heater core in the firewall. its a pain to change. took me about 5hrs but its worth the work for heat in the winter. if your motor isnt warming up then check the temp rating on the thermosdat you put in. it may not be the right one. just thinkin
Old Oct 6, 2010 | 04:53 PM
Id look into that TSB. Its specific for a '90 d250, if you somehow put that thermostat in there so it is always open, then your truck will take forever to get hot. its easy, check your engine serial number first and if its affected see if your head has a letter stamped on it.
Old Oct 7, 2010 | 12:32 AM
blazier18's Avatar
any oil in ur antifreeze?
Old Oct 7, 2010 | 01:59 PM
Billy D's Avatar
My serial# is before the one one the TSB, am I safe with that? I got no oil in my coolant, think I should replace my heatercore?? I'm not looking foward to that job... Is there a thread on replacing the heatercore? I'm not to hip on the dash removal. This could be a nightmare
Old Oct 7, 2010 | 04:16 PM
negative dont replace your heater core. if its not broke dont fix it. Being your before the cut off your engine IS AFFECTED. Look and see if your head is stamped with those letter(s), you may need to grind that passage out larger.
Old Oct 7, 2010 | 04:56 PM
Billy D's Avatar
I called Cummins Bridgeway, their in my area, they had NOOOOOO info on nothing. When I asked the service dude, " where's the stamp onthe head", he had no idea. WTF, this is Cummins, they'de never heard of such a TSD. Can anyone tell me where to look for the stamp? There's a 7L on the front right side of the head, is this what i'm looking for? The dude said I have the right T-stat (part# anyways) and it's never ran hot, I drove Goldie to DC which is about 600 miles with the A/C boomin in 90 degree heat, and she never ran hot. I'm kinda disapointed in Cummins giving my the cold shoulder, them F'rs. That service dude kept saying it's a heater core problem, I guarantee it! That ********!!!
I got one of them too, I followed the vaccum line, it seems to have no cracks, or breaks, as fer the valve deal, i'm not fer sure
