No Power
Old Oct 5, 2010 | 10:28 PM
12valveguy's Avatar
Default No Power
I have a stock 96 and its lacking power. On hills it wont do over 50 MPH when floored. It starts great, idles great, and run great. It only blow a little smoke on cold starts. Any ideas where to start?
Old Oct 5, 2010 | 11:34 PM
12vcummins96's Avatar
fuel filter
Old Oct 6, 2010 | 09:24 AM
12valveguy's Avatar
Just did the fuel filter and prefilter. Maybe I need to look inside the tank.
Old Oct 6, 2010 | 10:04 AM
big willy's Avatar
build your tranny and figure out what your goals hp wise are and build it that way so you don't just go get a full builet tranny and not need it and then get gauges and then go from there
Old Oct 6, 2010 | 01:13 PM
BIG NIG's Avatar
have the timing bumped to 15.5 and see how it runs......wile your at it move the plate
Old Oct 6, 2010 | 01:19 PM
ktfroy's Avatar
What's your fuel pressure like? I had the no power on hills thing and it was my lift pump going bad.
Old Oct 6, 2010 | 05:51 PM
12valveguy's Avatar
I dont have a way to measure fuel pressure
Old Oct 6, 2010 | 09:20 PM
blazier18's Avatar
straight pipe and cold air intake is a start if theres no mechanical problems. on top of that its a 3:55 gear aint it. mine was like that too. do you know where the afc housing is?
Old Oct 6, 2010 | 09:37 PM
12valveguy's Avatar
I dont know anything about AFC. I did notice that the pamper proof bolt is still on the cover.
Old Oct 6, 2010 | 09:54 PM
Heavy Smoker's Avatar
no o/d?
