5spd... slave cylinder junk?
Old Oct 5, 2010 | 09:41 PM
timsgsx's Avatar
Default 5spd... slave cylinder junk?
my 2000 24v just the other day backing into a parking spot my clutch lost all pressure. now i can get one solid pump and it goes dead. me and my buddy assume the slave cylinders probably leaking? bstill has some fluid however the oil leak i can find is between where the motor bolts to bell housing. is the slave cylinder internal?
i did one on my old gsx eclipse a few years back just wondering if this is more than likely my issue. any help appreciated
Old Oct 6, 2010 | 07:06 AM
johnyb59's Avatar
Sounds like the pressure is bypassing the internal seals of the slave cylinder. You should be able to pick up a replacement at your local auto parts store. Here is a link to bleed them:Hydraulic Clutch Bleeding Procedure
Old Oct 6, 2010 | 08:43 PM
timsgsx's Avatar
so the slave cylinder is on top of the tranny under the cab?
Kennyw250
Jan 14, 2015 07:47 PM
Oct 31, 2014 08:10 AM
91 7three
Oct 15, 2014 12:57 PM
