DTC 36 - Injection Pulse Width Error (Time Long)
Old Oct 5, 2010 | 09:30 PM
yamadude's Avatar
Default DTC 36 - Injection Pulse Width Error (Time Long)
truck info. 94 chevy 3500, 6.5 turbo, F code, automatic, 2wd. engine has 211,000 miles.
DTC 36 - Injection Pulse Width Error (Time Long), this code came up on the diagnostic check. what does it mean? my truck sounds like it is knocking from bottom end when at 1500 or above rpm. would this code have anything to do with that? thanks in advance.
Old Oct 5, 2010 | 09:54 PM
Crazy's Avatar
sorry but could be and hate say so but bad IP
Old Oct 6, 2010 | 12:40 AM
yamadude's Avatar
it starts pretty easy cold and very easy warm, and runs great. plenty of power. no stalling or anything. no smoke. i cant tell anything wrong with it. but it does sound like its knocking only when given fuel. not at idle. when i stick my head under the truck, while someone else works the throttle, it sounds like its coming from the oil pan. i have put over 200 miles on it this way with some towing. i am new to diesels, so it may be just the way they sound. i did change engines, so the code may be from the previous one. i cleared the codes and so far the check engine light has not came on.
Old Oct 6, 2010 | 10:19 AM
Crazy's Avatar
ok sorry i'll thought you where talking about the IP knocking
you said you change engines pull the cover off for fly wheel check make sure all bolts tight on converter i have seem a bolt back out and hit the block and sound like rod knock
Old Oct 6, 2010 | 02:35 PM
yamadude's Avatar
i'll check it.
Old Oct 7, 2010 | 10:33 PM
goobs's Avatar
when my truck threw this code it was the IP, but i found out later that it coulda been just the pmd.
i also have '94 same 2wd, etc.
Old Oct 8, 2010 | 10:58 AM
yamadude's Avatar
thanks to all for the info. i will check it out.
