6.5 dies on freeway
Old Oct 4, 2010 | 11:01 PM
maxfye's Avatar
Default 6.5 dies on freeway
I have a 1996 6.5 liter and when going 60 or 70 on the freeway it will suddenly lose power and just shuts off completely.
And after i pull over it will start right back up, its done it 3 times on the freeway and one time in town.
Any solutions or ideas???
Thanks alot!
Old Oct 4, 2010 | 11:08 PM
Crazy's Avatar
sound like PMD going bad where is PMD mounted at
Old Oct 4, 2010 | 11:09 PM
FastCR's Avatar
x2. Do some research on PMD failure. Diagnose by swapping with a known good pmd.
Old Oct 4, 2010 | 11:22 PM
Crazy's Avatar
here a site to read and tell you how test PMD
www.AccurateDiesel.com - PMD Installation Instructions - Accurate Technical Services, LLC
Old Oct 5, 2010 | 09:28 AM
maxfye's Avatar
Thanks alot I appreciate it!
Old Oct 6, 2010 | 11:04 AM
maxfye's Avatar
Default pmd
Is it hard to install pmd yourself?
Old Oct 6, 2010 | 11:40 AM
Crazy's Avatar
you going want to fine PMD with a heat sync and you want to move it to the front bumper it will last longer
here site you get one at
http://www.kennedydiesel.com/
or shop around
also if can fine good used one cheap get and keep it in truck for spear never know when one goes out
Old Oct 6, 2010 | 11:49 AM
maxfye's Avatar
Thanks
Old Oct 15, 2010 | 02:51 PM
Possmguts's Avatar
Its always a good idea I think to have 2 PMDs mounted beside each other if you can afford it, just in case. That way you just unplug the one and plug in the other.
One thing I DONT see in the instruction above, is MAKE SURE YOU GET THE RESISTOR out and put it IN the other one if it dont have it already. Its a LITTLE white colored thing INSIDE the plug on the PMD.
If you have 2 mounted, just buy another resistor on ebay, I see them all over.
I still have the OLD style PMD (black one) the new style is grey, IT HAS DIFFERANT HARNESS. If you just buy a new style (the old styl is no longer made) you HAVE to get the harness adapter.
Right Crazy??
Old Oct 20, 2010 | 07:56 PM
huffman red 1's Avatar
i had the same problem with my truck ,,and it ended up being injectors and glow plugs.
thatdude38
Aug 31, 2015 05:22 PM
JohnFromVt
Aug 3, 2015 06:15 PM
penley`
Jun 7, 2015 04:38 PM
JamesL91
Mar 15, 2015 06:11 PM
bdemutis
Nov 28, 2014 08:16 PM
