No overdrive
Old Oct 4, 2010 | 10:05 PM
steven-o's Avatar
Default No overdrive
last week i pulled off the highway for a second and my overdrive worked fine, and then i get back on the highway and there is no overdrive. and my top speed is 55 at 2500rpm
- i tested the tps and got 1v at idle and4v at WOT
- Brake switch was replaced about a month ago
- Tach and spedo still work
- my overdrive switch still goes out of overdrive becasue i can lock the convertor at 30mphs
Any Ideas?
1997 Dodge Cummins 4x4
Old Oct 4, 2010 | 10:26 PM
12vcummins96's Avatar
check the solinoid
Old Oct 5, 2010 | 11:23 PM
steven-o's Avatar
next on the list for tmrw. i just read somewhere to clean battery terminals, would that make a difference?
BUMP. need help asap
how do u test the solinoid?
- i was low on fluid. ...
Any Ideas?
Old Oct 6, 2010 | 08:03 AM
Fairmont's Avatar
how low was the fluid and how many miles on the trans
Old Oct 6, 2010 | 08:21 AM
steven-o's Avatar
it was pretty low and probably about 45k
Old Oct 6, 2010 | 03:06 PM
Fairmont's Avatar
it dont take much to burn up the over drive i blew a line on mine lost bout 4 quarts of fluid. Mine was done you can re build just the overdrive and never take the whole tranny out.
Old Oct 6, 2010 | 08:04 PM
steven-o's Avatar
but how would i know for sure it needs to be rebuilt?
Old Oct 8, 2010 | 08:27 AM
Fairmont's Avatar
you can put it on a scan tool and watch to see if it goes into over drive
Old Oct 8, 2010 | 01:05 PM
cumminspwr11's Avatar
or possibly put a pressure gauge on the od test port and see if its getting the pressure to engage, if it is getting pressure and not working then od is probally done for, if it doesnt get pressure it could be the solinoid
you can pull the od out while the rest of the trans is in the truck, you will need a press to get part or od apart
Old Oct 12, 2010 | 11:47 PM
steven-o's Avatar
im just gonna rebuild it. do i just need a regular rebuild kit to get the overdrive working if they are burnt?
