91 dodge 2500
Old Oct 4, 2010 | 03:54 PM
Bill Hughes's Avatar
Default 91 dodge 2500
No OD. changed vss, kick down cable and adjusted tps. Found bare wires at trans for od.
Old Oct 4, 2010 | 08:10 PM
wildbill's Avatar
Problem fixed then??
Old Oct 5, 2010 | 11:37 AM
Still no OD. Dont know if ecm sending signal to tran.
Old Oct 5, 2010 | 01:35 PM
kieron_kohlmann's Avatar
The SBEC is providing ground for the solenoid. The SBEC monitors your Vehicle Speed and Throttle position. If one of these 2 sensors isnt working then it wont go into OD. If you can plug into the Controller and see the codes it will most likely tell you whats wrong. you will need a DRB-II,DRB-III, or an aftermarket scanner like a Snap-On.
Old Oct 5, 2010 | 02:11 PM
Thank you.
nelly559
Feb 2, 2015 08:19 AM
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
