before i take her to the shop?
Old Oct 3, 2010 | 08:30 PM
DobermanDiesels's Avatar
Default before i take her to the shop?
ok i had another thread but i need some advice my truck started droping oil pressure the other day but the gauge would come on and go off, when it was off i cracked a line on the turbo and it was pumping so i figured sending unit, then it started feeling like the brakes where on leaving from a stop now it wont hardly change gears and when it does it only goes about 15 and then the engine just spends up on the rpm without going anyfaster on top of that it will not shut off when i pull the key out, i reprogrammed my adr and it would shut off but still had all the other symptoms and after testing it with a new usb update it wont shut off again and my adr reads 0 on everything even with the adr off it still does this!
i thought bad tc, or bad pcm i guess im gonna take it in i need a full billit job and a tc anyway but this has got me confused as hell
Old Oct 4, 2010 | 12:30 AM
First I would pull off the Adrenaline Completely including the harness and all. See how she runs then.
Old Oct 4, 2010 | 08:58 AM
biged681985's Avatar
sounds like electrical gremlins somewhere. like luke said, i would pull the adren off completely, and see what it does. the trans wouldnt cause the oil press. gauge to not work or the truck to not shut off. ive heard of the adren causing trucks not to shut off. i had a problem with that on a friends a couple times and had to unplug the adren just to get the truck to shut off. so thats for sure where id start. good luck
Old Oct 5, 2010 | 07:13 AM
thats what i am gonna try this morning i did have to unplug the adr to shut it off im gonna yank it off and check my grounds and what nots any more ideas i will post back in about an hour or so after i pull it.
well the only diff with the adr out is it will shut off it still wont shift and the oil pressure gauge comes on and off also i noticed it seems to be draining battery it was hard to start it did not roll over easy like normal
well i guess i have no choice but to take her i need some trans work anyway so i am gonna make that trip today and empty my bacnk account again
Last edited by DobermanDiesels; Oct 5, 2010 at 07:13 AM. Reason: Automerged Doublepost
Old Oct 5, 2010 | 07:20 AM
RAW's Avatar
RAW
, that suck. In regards to the batteries being weak, you could check for parasitic drains. It's rather straight forward as long as you have a decent multi meter.
Old Oct 5, 2010 | 11:20 AM
01quadcab's Avatar
how old are your batteries? when your batteries get old and weird it can cause electrical systems to do bad things. you may want to change them out first and see if that changes anything.
Old Oct 7, 2010 | 07:47 AM
i have mopar brand batteries about 6 month old i have a fluke meter and i have been thriugh this thinkg witha fine tooth comb i have done and checked everything that i would think could cause this they are coming to pick her up today since it wont move now i guess i am happy about thati want a new tranny and i need a new airdog i am thinking of putting some sticks and a turbo i have a 5" str8 pipe to put on it also but im not sure about the turbo change yet
mfr63
Sep 20, 2015 05:27 AM
Josh923
Sep 10, 2015 11:16 AM
roanokerivermud
Aug 12, 2015 03:07 PM
Aug 4, 2015 09:00 PM
Nicholasblake
Price Quote - Request A Price
Jan 17, 2015 01:48 PM
