85 6.9 guidence
Old Oct 3, 2010 | 06:55 PM
tb6.9ford's Avatar
Default 85 6.9 guidence
Im fairly new to diesels. I just got my first one picked it up pretty cheap. Its a 85 f250 6.9 in it. it runs good. But it has some bugs that need to get worked out. First the battries drain overnite, there used and i wanted to get an idea of what could be drainin them before i get new ones. Also it smokes blue and white when first started and then continue after fairly warmed up. Wonderin if it just needs an oil change (which im planin on doin once the weather is fair) or what it could be. Oh and lastly what is the best oil for these rigs?
Old Oct 5, 2010 | 10:48 PM
Sycostang67's Avatar
A bad diode in the alternator can kill batteries pretty quick. If you replace the batteries, make sure the new ones have at least 1000CA each.
The smoking could be due to your timing being off, a bad injector, stuck rings. We will need more details on that to further diagnose. Changing the oil could help if it is old and thin though.
As far as oil, get 15-40 and pick a brand. You may notice that your truck consumes more of one brand than another. Change it and keep track of how much you have to add before it is due again, then try another brand if you aren't satisfied. Everyone gets different results with the same oil so find what works best for you.
Old Oct 14, 2010 | 04:06 PM
tb6.9ford's Avatar
well i changed the oil and oil filter and it seems to be smokin less but i havent let it warm up all the way due to im almost outta diesel. but i might have found the prob with the battries. i testin stuff with the voltage tester and i found one of the horns was still live so keep ya updated when i get the plates for the truck
Blanton
Apr 15, 2015 06:29 PM
greasesheik
Apr 9, 2015 09:33 PM
tumble72
8
Nov 27, 2014 10:31 PM
Bigredpowerstroke
Nov 12, 2014 03:33 PM
tumble72
Nov 10, 2014 08:41 PM
