02 Cummins acts like it is not geting fuel when pedal is pressed
Old Oct 3, 2010 | 09:59 AM
Lilcasper888's Avatar
Default 02 Cummins acts like it is not geting fuel when pedal is pressed
I did a 5 min search but didnt find anyone with the exact same problems so decided to ask, my 5.9l 2002 dodge ram 2500 cummins with a 47re is trowing codes I keep clearing them and as soon as I start the truck they come back. My codes are p0121 p0122 p0222 p0236, I've looked them up but I dont know what I'm looking at . someone smarter than me please help, I put a new timbo apps in with in the past month to get rid of the p0122 code I was getting. It stopped for a month and ran fine than started doing this, I also have a new fuel filter I put in at the same time. It feels like the truck is not getting any fuel as soon as I press the pedal, but idles fine, I'm hoping its not the vp44 thanks for any help you can give.
Casper
Old Oct 3, 2010 | 10:06 AM
RAW's Avatar
RAW
Are there any modifications done to the truck and engine? Please list any that are done.
P0236 is an over boost code, the rest are all related to the APPS. When the new APPS was installed was it rester?
Old Oct 3, 2010 | 10:17 AM
Yeah, sounds like APPS
Old Oct 3, 2010 | 10:21 AM
thanks for the replies the only mod i have is an edge power comp, rester? I did do the apps reset is that what your asking? thanks again for the help
Casper
Old Oct 3, 2010 | 10:22 AM
crazycooter's Avatar
I would agree with DR Evil your apps either has really bad connections, or more likely done for.
Old Oct 3, 2010 | 10:25 AM
RAW's Avatar
RAW
Oops, sorry about that. Reset is what I meant.
Old Oct 3, 2010 | 10:30 AM
when I put a volt meter on the apps it goes from .609v to 4.v smoothly is there some other test to do?
Thanks
Casper
almost forgot i did do an apps rewire a wile back, the one where you tap the wire at the apps and run it to the pcm
Last edited by Lilcasper888; Oct 3, 2010 at 10:30 AM. Reason: Automerged Doublepost
Old Oct 3, 2010 | 10:33 AM
RAW's Avatar
RAW
You can try a reset, no promises though.
-Disconnect batteries for a 1/2 hour, then reconnect.
-Turn key to run, but DON NOT start
_Depress pedal all the way to the floor, and then bring back up. Do both motions taking about 3 seconds to complete the travel each way
-Key to off, then run as normal.
This teaches, or relearns the the position and travel of the APPS into the computer.
Care to explain that one a bit more?
Old Oct 3, 2010 | 10:36 AM
I'll go do that now, and come back in about an hour to give an update.
Thank you
Casper
http://www.suncoastconverters.com/im...d%20rewire.pdf
http://www.suncoastconverters.com/im...oundrewire.pdf
I hope this link works
Last edited by Lilcasper888; Oct 3, 2010 at 10:36 AM. Reason: Automerged Doublepost
Old Oct 3, 2010 | 10:40 AM
RAW's Avatar
RAW
First link works for me, and I have done that one as well. The second one I can not view.
